Spandex pants
[email protected]
Where can I find some spandex pants for Victoria 4? I've searched and can not find anything so far. Please aid ...
Probably because most of the time the easiest way would be to use a V4 bodysuit and applying a shader.
Even easier - just apply the shader to V4's material zones.
The V4 morphs include a "spandex" morph for the hips. It smooths out her booty so it looks like spandex, not paint.
Yes, but if you want to do things like add cut-outs. laces up the side or other 'fancy' stuff, it's hard to do if you've used her skin. Where a bodysuit and a transmap will get you whatever you want.
V4 Bodysuit, can be turned into lots of different things.
http://www.daz3d.com/shop/victoria-4-2-bodysuit
Thank you!. I have it already.
What is needed is an AWESOME spandex Chest morph. The ones I have.....just don't quite make it.
If you have time and inclination, you can do a lot with D-formers. I'm not that great with them myself, but if I fiddle long enough, I can usually get an approximation of what I want.
