DSON + Queue Manager Issues
c567591a
Morphs in particular do not work when rendered in Queue Manager. :(
The same scene, no changes at all, when rendered INSIDE Poser itself works fine.
For instance with the Horse2 + Barding, the shape morphs for the Horse do not apply (essentially appear to be set to 0) nor do the head/tail movement morphs.
The Barding is in the right place assuming the morphs in the horsie had worked. However since the horse shrank and the head/neck rotated back to 0 position, it appeared floating above the horse. :(
Is there some directory with morphs that I can copy into the main Poser directory (ie like you have to do with Python Scripts) to make this work?
