Genesis 3 a workaround
WendyLuvsCatzWendyLuvsCatz Posts: 38,374
edited November 2016 in Carrara Discussion
what you need
what you are doing
converting the mesh to a Carrara compatible figure but keeping mesh and shaping morphs
you need GenX as the pose morphs will not work so you add the morphs for another compatible figure
the workflow
  • use GenX to inject the desired facial pose morphs, expressions, visemes, blinks etc it can be from Victoria 4 even as long as morphs not controls,
  • load the figure and your desired target, I used genesis 3 male and genesis 2 male
  • fit to
  • choose full body
  • save as support asset actor
thats it
easy
OK it will work in Carrara and use poses in my case for Genesis 2 and with tweaking earlier poses
it can use facial expressions under genX so a mimic dmc for the figure you sourced them from will need those and prob moved to the head in edit mode mover, not tried yet only dialed some in so far.
some textures/materials load most do not depends how the PA saved them, 3DU little ones and Jolab's Torak worked for me most others got an error, resaving in D|S may work I still need to find the best way.
Otherwise load maps manually.
I will add updates to this thread and videos as I play with it
as you see from video some morph presets will load but can tell you now most will crash Carrara to the desktop
dialing the best action
and it can only use those you have when you saved the figure
if you buy more you need to resave it as a support asset
oh it can wear most clothes for your target figure out the box too.
957 x 995 - 197K
1361 x 719 - 238K
577 x 993 - 118K
  • video with expressions
    I have since brought G2M visemes over with GenX but not getting them on head for Mimic using mover, might have to edit the dmc instead
  • magaremotomagaremoto Posts: 1,227
    my time to say scary..but cool
    this looks like a new arrival: http://www.daz3d.com/genesis-3-uvs-for-genesis-2-male-s
  • my time to say scary..but cool
    geografts
    not gonna work in Carrara sad
  • I am having no luck with Mimic either
    I saved it in PoserPro2012 using DSON loader as a cr2 and loaded it in Mimic pro and dragged the visemes from the body on the object tree to the window but unless on head do not seem to want to work
    they should, other things have had on body
    notepad editing gave me no love either
    the G2M visrmes work but short of creating nla clips for them all cannot drive with mimic
  • DartanbeckDartanbeck Posts: 21,644
    So I'm not sure I follow your initial instructions.
    Are you making a Genesis 3 morph for Genesis 2? Or using Genesis 3 mesh as clothing for Genesis 2? It's kinda vague what we're supposed to do there.
    Either way, if you can get facial morphs working in Carrara, Mimic Pro for Carrara should work. Just make your own adjustments as NLA and it should work - I'd think.
    Oh... I forgot to add: Thanks! This is so cool!
    Too involved for me, but I know that there are many people who will be happy to try this!
  • WendyLuvsCatzWendyLuvsCatz Posts: 38,374
    is making as clothing
    just autofit then save as support asset
    only involved part is adding the g2M visemes with genX but if you adding other morphs with genX anyway just a few extra ticks
    and yes could do by making NLA clips manually
    Cool yes
    I might have to try it just for fun. I'd have to get GenX first.
    Just a thought, if it's using Genesis 3 as a clothing item for Genesis 2, wouldn't the Genesis 2 expressions work on the conformed Genesis 3 clothing?
    Part of my issue with using Genesis or Genesis 2 for Rosie is that her expressions deform (slightly - bit enough to look really odd in animations) her auto-fit V4 hair.
    I started the process of making my own G2F Rosie hair, but never finished it. Maybe one day?
  • it would if you loaded it on Genesis 2 as clothing prob
    Now I'm lost. I thought you just said that's what we're doing here?
  • do not need GenX just if wanting to add morphs you could as you said load it on a genesis 2 and hide that
    well I saved like clothing but used it by itself
  • I was using autofit to convert it to G2M rigging so it worked in Carrara
    not as a wearable
    but using the process used to fit clothing to do it
  • and no seems loading it as clothing the visemes do not work either
    Wow... I see! That's really cool!
  • StezzaStezza Posts: 8,167
    I got George for G3 into Carrara... and wearing the Santa suit for G3 as well.. by just using G2 & GenX
    Q. Is there a utility that transforms G3 maps to G2 and G1?
    I actually bought my first G3 products ever!.... just to see if it worked of course wink
    800 x 600 - 242K
    really great find... got a carrara 9 with few bucks laugh
  • chickenmanchickenman Posts: 1,202
    but it uses geografting so not good for us directly.
  • well my way you do get to use the skin
    Meaning that the Genesis 3 UVs remain intact! ;)
    well it is the Genesis 3 mesh
  • I may this weeking try and create some NLA clips to populate mimic pro for Carrara
    using the Genesis 2 visemes if anyone adds them with GenX
    Right. That's what I meant... Just trying to clarify a bit ;)
