UV and Material Zones?
KickAir 8PKickAir 8P Posts: 1,865
Asking questions when I'm not near my 'puter to have DAZStudio up, please pardon the extra cluelessness:
An object's material zones are specific to the UV, aren't they? So if I pull up an alternate UV, it could (and often does IIRC) have different material zones?
I know it's possible to set up material zones in DAZStudioPro4.5 (although I haven't tried it yet), is it possible to set up an alternate UV? If there are directions on how to do these up somewhere I'd appreciate a link.
  • Richard HaseltineRichard Haseltine Posts: 100,009
    No, it's the other way around - the UV Set is a setting for each material zone, the boundaries remain unchanged on the model though they may vary on the template.
  • wancowwancow Posts: 2,708
    Yah, I just found this out... trying to re-establish the gen material zone on the female genitalia... didn't work :(
  • Canary3dCanary3d Posts: 2,023
    Here's a tutorial I wrote that shows how to make custom material zones in DS4.5 pro - super easy, I promise! http://www.canary3d.com/tutorial/Tute-CustomMatDSPro.zip
    Thank you, Canary :)
  • BejaymacBejaymac Posts: 1,886
    edited December 2012
    Be careful when changing Material zones on an existing DSON figure, always do it to a copy (created with "Figure/Prop asset") otherwise you'll break the original figure and it's texture sets, to the extent that you'll have to delete your work and reinstall the original to get rid of stray mat zone references in the DSF files.
    PS this is why we can't use Gen 3 textures on Genesis, they would need to supply a second version of Genesis with Gen 3 material zones and UV's.
    Post edited by Bejaymac on
    What you can do is use UVS files to tranferre UVs in UVMapper.
    Only if the basic geometry matches. You couldn't use UV Mapper to transfer third generation mapping to Genesis, and for Genesis you'd need to rerig any remapped OBJ with the Transfer Utility.
    You can remap an exported genesis OBJ without re-rigging...you just load the new OBJ in the surfaces thing as a new UV. But the 3rd gen figures have geometry that's very different from Genesis, so getting it line up is pretty difficult/possibly imposible.
    I was meaning if the zones were changed using UV Mapper or the like.
  • DavidGBDavidGB Posts: 565
    Do you still have the last original female genetalia files from where there was the gen zone? Or the installer to install them in another location?
    I loaded the new files, the old files, and the latest Male gens files (as a comparison of the current latest format that has two material zones one skinhip, one gendetails) into a text editor to compare, then just hacked the info for the gen material zone from the old V5 Genetalia into the current Genesis Female Gens.
    You need the Genital Detail.dsf from the UV Sets/DAZ 3D/Base of the original female genetalia's data folder, and the texture file for the gens details, but it only needs ... I think it was three pastes into the files of the current female gens files to return the gen material zone - and they then reappear in all UV sets for the female gens: V4, V5 and S5.
    I could write instructions, I suppose. It's not really at all complicated.
  • KickAir 8PKickAir 8P Posts: 1,865
    Sorry people, didn't get back to my computer last night to try any of this, but I appreciate your help!
  • Art_JunkieArt_Junkie Posts: 0
    Could you please post exact instructions on how to do this?
    Thanks
