a few not-really-credible .obj nests and the script that generated them
mCasualmCasual Posts: 4,607
edited December 2016 in Freebies
this was just a quick script i put together
but if you have even minimal programming experience
you should be able to use the methods shown here to procedurally generate objects
only attempt to use the script if you understood it enough to manually adapt it to your PC's file paths
https://sites.google.com/site/mcasualsdazscripts8/mcjfakenests
800 x 600 - 282K
960 x 720 - 501K
Post edited by mCasual on
  • grinch2901grinch2901 Posts: 1,246
    I've decided in 2017 I will dig into scripting in Daz Studio. My inspiration was mostly the amazing things you do with scripts, as well as a couple of the PAs here. There is clearly a whole untapped world of possibility in Studio that the imagination can unlock via the scripting API!  Of course I haven't done any script development or coding of any sort in probably 20 years.  Basic, Fortran, ANSI C, C++, Java, Javascript was my evolution up until that point, however except for the minimal Javascript work I did it was all for engineering problem solving i.e. brute force math intensive calculation work.  As a result my coding style is not very elegant and will have to improve.  It will surely take quite some time for me to do anything worthwhile, so I appreciate you dropping a script that simply illustrates a priniciple as a jumping off point.  Thanks!
  • mCasualmCasual Posts: 4,607
    it's basically javascript
    for( var a = 0; a < 10; a++ )
    var answer = add( a, 2 );
    debug( a + " + " + 2 + " = " + answer );
    function add( a, b )
    return( a + b );
    263 x 197 - 15K
  • MilosGulanMilosGulan Posts: 1,955
    Wow looks great, thank You very much.
