Smooth move Exlax.
The smoothing modifier has been driving me nuts.
I just cannot seem to get a setting out of it what works reasonably. For every poke through problem it fixes it seems like two more pop up somewhere else. What is the secret to getting this working?
If this is for clothing...combine it with a Push modifier...something small. The Push modifier defaults to 1 cm...0.01 cm is quite enough to take most clothing 'off the skin' and allow smoothing to 'stand off' the surface, You can also set the 'push' to be above the bump/displacement (which can cause 'hidden' poke through...you don't see it in preview, but shows up in a render).
Ah! I didn't know the push modifier could be adjusted. This changes everything! :lol:
