Fur Jacket
beachlegs
I am looking for a fur jacket for k4, Here is a pic of what I am looking for if possible.
360 x 253 - 23K
Sorry this is in the wrong place was ment for General freebie section.
Moved to the Commons, as it is a request for, not an offer of, a freebie.
If you've got Furrify, there are several fur shaders which could be applied to an ordinary jacket. You can't see the fur until you render it, but it does quite a good job.
Or you can just use displacement. this was an image to see if i could get semi realistic looking fur with displacement and it wasn't hard. then again, this was rendered in Lux, but shouldn't be much different in any other renderer that uses displacement. just create a noise map and tile it about 20 times and subdivide the jacket a couple of times.
Thank you all so much everyone...FSMCDesigns I am not sure what displacement is and have no idea how to create a noise map ect as I am not Technical
with poser yet but I will have a nosey and see if I can work it out myself as I like to learn that way...Thank's again everyone :)
This blazer, though not perfect, is sort of the right shape.
http://www.renderosity.com/mod/bcs/k4-girls-japanese-uniform/83313
For the fur, maybe WhopperNnoonWalker-'s Store? Everything is on sale and they do have some fur textures.
http://www.renderosity.com/mod/bcs/index.php?vendor=308023
Hope this helps. Dani
Thank you so much Dani I am sure I can work with them, The fur look's wonderful will give them a try
as I can alway's use them on other item's...Thank you :)
