I'm German and I can't find the adjustment option :red:to change the viewcontrol in the moment I'm dragging or turning the model. Since some days I can only see white marks and angles of the model then.
You need to go to Window > Tabs > Tool Settings, and change the DrawStyle to 'Use Current (Off)'. It is probably set to Switch to Wireframe Box at the moment. See if that helps.
Thank you sooo much, dear Jimmy! Have a magic Xmas!!
You are most welcome!
And a Merry Christmas to you and yours.
