Gees we will need more info than that before we can help.
Did you save the obj or download it....
what import options did you use and have you tried other settings...
are the surafces ok....
it is scaled that low you can't see it....
What is the item if it is a downloaded one, a link would be better.
Its a char object that i downloaded from the net.
When i click import option and select the obj file of the char.
Char does load but its invisible, i can see the wireframe mode, but its invisible in all other mode
