Gorilla feet
dylyn.prosserdylyn.prosser Posts: 0
I have the Genesis Gorilla. I noticed that in the Parameters tab, you can apply just the Gorilla head to a Genesis figure. Is it possible to save just the feet as a morph so they can be applied the same way? I've messed around with exporting, Morph Loader Pro, and the Figure Transfer Utility with no luck.
(I use DS4 & I have Hexagon 2.5, although I haven't done much with it.)
    You would have to find a way of projection only certain parts of a morphed mesh onto a plain Genesis mesh - I don't think Hexagon can do this, modo can (but ti pricey) and I think Blender can. Then you'd apply the morph to just the feet, reposition the feet (since they'd be moved to the end-of-gorilla-legs positions) and export as OBJ, which you would load as a new morph with Morph Loader Pro. The tricky bit is always going to be getting the partially morphed shape to load as a morph.
