Animation and keyframes
NinjaUmbreonNinjaUmbreon Posts: 21
edited December 1969 in Art Studio
I've been trying to do some animation in Daz 4.5 but I've been have some problems. I though I now how key frames worked, but I've noticed some odd trends. I've found that even with stopper key frames, object and the camera will drift. Dose anyone know what cause this?
Also, anyone now any good tricks for have a character pick up and move an object in an animated sequance?
  • bighbigh Posts: 8,147
    if you have the full version of aniMate - it comes with a way to do what you want
    or you can use two obj - one you can see - then switch them
    or you can render the animation in parts - put them together in your video editor
  • carolinebegbiecarolinebegbie Posts: 162
    Probably interpolation.
    If you don't have linear interpolation (that's the way the frames that aren't keyframes are calculated), then you can get drift.
    Casual explains it well here:
    https://sites.google.com/site/mcasualsdazscripts/setinterpolation-for-ds2-3
    Casual's script allows you to change the interpolation, or Go Figure's graphMate allows you to do it more graphically. Casual's script may not work in DS4 - I haven't tried it.
    Some links to add to bigh's post:
    Casual showing how to make things visible and invisible, looking as if you are picking up and putting down:
    http://youtu.be/Eko4ZhFLTRc
    If you are using aniMate2, then go here:
    http://www.gofigure3d.com/site/index.php?option=com_content&view=article&id=93&Itemid=87
    and there is a video on constraints called Parent Constraint.
  • NinjaUmbreonNinjaUmbreon Posts: 21
    Thanks for the feed back.
