just a little heads up on Network Render
protovu
Hi All,
Just discovered that when using Network rendering, if there is an Octane Material lurking in the Carrara file.......even if it is not being used........it will prevent the node computer from loading correctly.
I had a file which I was rendering in Octane, but needed to switch back to native Carrara render. Would only load 37%....many grey hairs later......this was the problem.
Cheers
Great tip... thanks for this ;)
