Poser Companion File Error
mathman
Hi,
Why am I getting this error when trying to create a Poser Companion File from a duf file ?
Any help appreciated.
thanks,
Andrew
1152 x 648 - 45K
Hi,
thanks,
Andrew
Do you have SR3 for your P9/Poser Pro? This was the cause of the error in my case.
Yes, and its worth noting that I was able to successfully create a PCF for a Material preset.
Thanks.
Have you double-checked your versions of DSON, the companion files and the core? Version mismatch can also cause this error.
I don't know how to check the version of DSON, the companion files and the core. Can you please tell me how I can do this ?
The installer names have the version.
The version numbers are:
DSON : 1.0.0.13
DAZ Studio : 4.5.1.6 Pro
Poser : 9.0.3.23027
Does this tell you anything ?
Hello ?
I have exactly the same versions ... I am adding a screenshot of my settings.
(as I don't use metadata, I don't rely on them for getting the correct library and extension)
Did that help?
To be honest, I haven't tried it.
I have been working on numerous other problems, and haven't got back to it. I will aim to let you know when I have some results.
Thanks.
