Carrara 8.5 not finding Genesi…
Daz 3D Forums > Software > Carrara Discussion>Carrara 8.5 not finding Genesi…
Carrara 8.5 not finding Genesis Materials - Solved
Morphs show up in both. But Materials only show up in DS not Carrara. >:(
Updated the meta-data in DS...nothing.
Any ideas?
Thanks
P.S This is the product
http://www.daz3d.com/creatures-orc-horde-genesis
Post edited by harlequin-3d on
"DAZ Studio Material Presets (.DSA)"
Wont work in carrara.
Ah...that would explain it then.
Thanks for the info.
So. Wait.
If I just wrote a script that converted the DSAs into PZ2s, I'd be good to go with all these materials and things that I can't find in Carrara?
Not sure. The DAZ materials are probably based on image maps, but probably use special features of the D/S shading engine for effects. If that's the case, then they may not translate correctly if at all. Would the newfangled DUF get most of that data translated over from D/S?
I think it's just a text formatting issue. Which is why I think it's possible to write a script to scrape out the required info from the one file and move it to the other. That's stuff I do as a part of my day-job.
Both of these file types are text files with no binary in them -- I searched through my runtime to check it out. Both files refer to jpgs but in some cases, there are examples of both files that point to the same jpgs.
If I get some free time, I'll see if I can write a little php conversion routine.
Considering this has been an on going issue since DAZ bought carrara, I doubt it has that simple of a solution. Or some one would have done it by now. carrara has never been able to read a DSA.
