DAZ Collada (DAE) import oddity
clive_27d11c9e1bclive_27d11c9e1b Posts: 0
Hi I'm new to Carrara - but a long time Poser user
I'm possibly starting in an odd place, but I have some existing models in a non-standard format (includes meshes, morphs and bones), so I'm writting a translator to the DAZ collada format (as that seems most appropraite for models with morphs)
I'm starting by generating some simple geometries (basically modified cubes), and looking at the DAE files generated.
Here's my question. I added a simple morph to a cube, and saved the scene in DAZ collada format. When I reload it, the Morph Area list is empty, or at least It has a defined slot, but with no name. Clicking on the slot and the slider for the correctly named target appears.
Should this happen?
(to add to my confusion, if I save in standard Collada format, when I reload both the morph area and target have disappeared)
Thanks for any help
  • Kodiak3dKodiak3d Posts: 223
    DAZ never really perfected the Collada format or DAZ Collada. With the invention of the .DUF format, I think hopes it .DAE ever working properly are low.
  • bighbigh Posts: 8,147
    edited January 2013
    Should this happen?
    Thanks for any help
    it used to work - then they fixed it - now it doesn't
    edit to add -
    now with DUF - they said no more support for DAE last time I check
    Post edited by bigh on
  • RoygeeRoygee Posts: 2,247
    Which is a great pity - Optitex dynamic clothing used to work fine imported into Carrara with Daz Collada - not so with DUF:(
  • WendyLuvsCatzWendyLuvsCatz Posts: 38,504
    I can get Optitex clothing to work with .duf
    So you are running a cloth sim in D|S, then rendering it in Carrara?
    That's impressive! I didn't know that ever worked....
    edited January 2013
    Queen of Ages dress on V4 have done Genesis too, if not conformed you need to parent or the sim will not export, has to have morphs frozen to timeline.
    nightie parented to Genesis
    Genesis V5 in dress rigged for her
    Yep, we've had this conversation before - some of us can, others not and there seems to be no valid reason why. Anyhow, it has been reported and acknowledged by Daz.
    Anything that needs freezing to the timeline in Studio won't work with DUF for me - not Optitex or Animate - every other form of DUF works fine!
