Got DSON working but now,,,
ldc265ldc265 Posts: 0
Now everything else doesn't work. I cant click on any other tabs such as lights, props, pose and such. I can now load the genesis characters into the window but as soon as I do, none of the libraries work so I can't even apply any textures if I wanted to.
I have the DSON importer scripts both pointing to a folder in documents and settings where I have the DSON files. I had also put all the files from the gen characters in that same folder. In poser, I created a new file in libraries that contains the genesis files. Everything works fine until I load a genesis character file into the scene and then nothing else works. I can manipulate the character itself but can't add anything to the scene. I don't get it.
I have windows xp 32bit.
Why this new problem?
  • Richard HaseltineRichard Haseltine Posts: 99,468
    Go to the Scripts menu, the DSON importer sub menu, and then click the preferences command - turn off the option to show then progress bar when loading and you should find, after a restart, that the library panel no longer freezes.
  • ldc265ldc265 Posts: 0
    Works fine now, thanks.
