Noob question
norte31_e761ee3f47
I have a problem, when I move a figure or object in the viewport, rotates and moves or zoom on wire when I stop moving the controls again shaded smoth
563 x 761 - 97K
Have you checked your Draw style?
Yes , the draw style is off
Hi...
If this is happening while moving the figure or changing your view, then the Draw Style during manipulation is set to "Bounding Box"... you need to change that if you want to always see the figure...
Open the Tool Settings pane... Windows > Panes(Tabs) > Tool Settings
Change the Active Tool to something like the Universal Tool... then in the section labeled "During Manipulation" change the Draw Syle to "Use Current(off)"
Hope this helps... :)
