Highlight on transparency?
[email protected]
I applied to an area full transparency, but still appear the highligts that area. Why?
919 x 586 - 34K
919 x 586 - 35K
Check and see what your reflect it set at
What application? In DAZ Studio, make sure under Specularity that "Multiply Through By Opacity" is on.
Select your Trans area/(item) in the Surfaces Tab and make sure all Settings are at Zero for Specular, Refection, and Ambient. Set all those to NONE if they load a Map file as well. Then do a test render for just that Area.
