multi layer, multi layer element
dot_bat
Can anyone tell me if i am using this shader correctly. Im not familiar with the multilayer and layer elements. im using it to put the text on the bottle. and it seems tp work. Is there a better way to use this? thanx
197 x 406 - 9K
500 x 336 - 95K
From the screen grab I can't see how your Multi-Layer is set up, but if you are happy then you are probably doing it right. ;-)
