Illuminating Lamp Shades (WARNING: NO NUDITY)
wancowwancow Posts: 2,708
I did this render (WARNING: NO NUDITY!!! OMG! does that mean you won't look?)
http://wancow.deviantart.com/art/room-for-two-348644476
Anyway, I'm hoping someone could clue me into what kind of settings I need to get the lamp shades to look more like this:
http://pnn32.deviantart.com/art/Octane-Mesh-light-and-Transmission-material-344553128
The bulbs in the lamps have UberArea light applied...
I tried applying transluscency and 90% opacity to the lamp shades, but I couldn't get them to pass light through them and become illuminated.
«1
    edited January 2013
    Maybe put a light in the lamp ? In Bryce or poser I would put a small light inside and adjust the fall off
    A naked lamp. :coolgrin:
    Post edited by Chohole on
  • Richard HaseltineRichard Haseltine Posts: 99,954
    What I do is use ShaderMixer to create a shader for the shade that uses a Ray Type test brick (Functions>Utility>Ray Tracing) to vary the opacity - low for transmission rays, higher for others. That, plus translucency, can give a good result for things like lampshades which are not served well by the standard shaders.
  • wancowwancow Posts: 2,708
    Oh... :( or: it's gonna be harder than I thought :)
    Thanks Richard! So, Shader Mixer... something I've been avoiding... I guess I can't do that no mo... :) I shall return to this thread when I have completely pulled my hair out playing with the SM... :)
    This is where I'm at at the moment...
    This is the very first time I've enabled the shader mixer tab... I'm... a little lost :)
    I shouldn't be, but I be a wee bit lost :)
    295 x 643 - 70K
    691 x 554 - 97K
    edited January 2013
    The brick should be testing for Transmission rays, and it gives a true/false output - you need to feed that to an If/The/Else brick (Utility>Control) with the colour for transmission rays (dark, as we want it more transparent) and others (light, so the shade isn't see-through).
    728 x 439 - 36K
    Richard's way is the best...but you can get 'passable' results with using UberSurface on the shade...turn down the Diffuse strength (to about 30%) and turn off things like 'velvet', sss and so on...just use translucency....and set it to something like 70% (Diffuse + Translucency = 100%).
    No, it's not quite the same, but is a quicker 'fake'...
    I got sidetracked with Wendy's new undies for Genesis... I'm easily distracted by sparklies :)
    I think I"m going to focus on doing it Richards way... or at least try...
    Sneaks in to watch and learn...
  • SzarkSzark Posts: 10,634
    Popcorn Pen?
    If I sucessfully build a shader, Pendria, I'll post it on ShareCG.
    Szark said:
    Popcorn Pen?
    thanks...I'd offer you a tim tam but they're all melted from the heat. ; )
    thanks Wancow! It would be interesting to look at the network.
    Oh no don't get Pen started on Tim Tams again. LOL
    Yes anything shader mixer these days and I am all over it and saving a lot of info and links.
    Its too hot for timtams ; ) lol...at 39 they just melt before you pick them up unless you stick them in the fridge.
    I'm also into shadermixer...the more I find out the more I realise how much I don't know...
    I am so scared to ask, but as I was born the year of the cat, and I am a Leo... curiosity, and all that...
    What is a Tim Tam?
    A really good, chocolate cover 'biscuit' (cookie for those of us who speak American)...made in Australia. They are rather popular there...and in a few other places, nearby. They are available here, in the US, at Target stores...usually only over the winter months.
    You can create translucent surfaces using UberSurface shaders. The lamp below was rendered using this technique with an area light thrown in for general illumination.
    897 x 884 - 698K
    Hmmm... interesting... I wonder if Tim Tams are the reason I can't get Marzapan over Christmas anymore... :(
    HOF, can you tell me what setting you used on the UberSurface?
    In the image above, I just turned on Translucency and set it to 40%. The lighting was done using a point light and a spotlight pointing downwards (since the point light alone wasn't giving me the light spread underneath the lamp). The lamp shade texture was used as a translucency map, as well as for the diffuse map.
    Not just really good...they are the best chocolate biscuit you have ever tasted. They are very big over here...but at the moment it's so hot(yesterday was 39c) that chocolate melts in the cupboard so your more dedicated chocoholics store chocolate in the fridge. Wouldn't have mentioned them but I got offered popcorn...lol
    I had a friend in college, from Australia (and another one from NZ)...and he used to rave about them all the time. He even shared once...
    mjc1016 said:
    I had a friend in college, from Australia (and another one from NZ)...and he used to rave about them all the time. He even shared once...lol Sharing lol...they must have liked you a lot to share...lol
    Sorry Wancow for taking the thread off track...
    I never mind when discussions go off track... hell, I'm as guilty as anyone here :)
    Managed to get this! Thanks for all the help, everyone... I'll post the two relevant shaders in a bit.
    474 x 603 - 163K
    Looks great!
    Well, I did have to break out my bottle of Chivas in compensation...
    HoF...yeah, that's what I was talking about...except I've always done it balancing the Diffuse/Translucent numbers. (I need to install that lamp pack that was a freebie a few weeks ago..I thought I had some other lamps installed, but can't find them...this one has reversed normals, it looks like).
    800 x 1000 - 403K
    lol...
    wancow said:
    Thank you...downloading to have a look.
    Please post any results you get, good or bad :)
