zbrush problem
I am trying to reach a Zbrush screen, but cannot find an icon to reach it. I tried going to 'file' and using 'send to Zbrush', but I get this message :'unable to connect with Pixologic Zbrush, check installation'.
I tried re-installing GoZfor Daz Studio (correct bit and file- exe.pc) twice, but did not solve problem.
Any advice?
(And how can I get directly to Zbrush window?'
Where are you installing it to?
Program says that it is installing to: "C:\Program Files\DAZ 3D\DAZStudio4".
Do you actually Have ZBrush installed?
I thought I did. I downloaded it with Daz4.5 I mistakenly re-downloaded it later, and it uninstalled before I could cancel, and re-installed.
If Zbrush IS installed, How do I open it? From Daz? What Icon opens it?
You have to have the zbrush program installed for the plugin to work
The ZBrush bridge (GoZ) is a link to ZBrush, it isn't the application itself. If you don't ahve that, from Pixologic, then you don't need and can't use the GoZ plugin.
