Textures getting messedup
My chars textures gets messedup after using tranfer utility of genesis.
Any1 knows how to fix this
    What textures are you using, and on what character? What version of DAZ Studio?
    Can you post a screenshot of what your poblem looks like?
  • edited December 1969
    Before and after transfer utility
    612 x 818 - 46K
    697 x 793 - 46K
  • Richard HaseltineRichard Haseltine Posts: 99,954
    What are you using the Transfer Utility for? What settings are you using?
    I am using transfer utility to rig char and transfer morphs
  • ReDaveReDave Posts: 815
    What does it say under Surfaces->UV Set, before and after you use the Transfer Utility?
    Before transfer utility there is nothing after transfer utility. it says default UV
    I'm not sure why it's doing that, but I suspect you may not be using the right tool anyway - the Transfer utility s for transferring rigging and weights from a figure to an item designed to be fitted to the figure, I suspect you are using Genesis as the source for a figure with a different zero-position and therefore it isn't going to give useful results anyway.
    Hi can you tell me any other way to transfer rigging and weights
    Transferring makes sense only if you have a suitable donor - a figure with the same zero pose that you want to bend in much the same way. If not, assuming the clothed woman in your screenshots is the whole figure, then you really need to rig from scratch - use the Figure Setup pane to create the bone hierarchy, and to assign the mesh to the figure, then create it and use the Joint editor, Polygon Selection and Weight painting tools to edit it.
    Transfer Utility is correct for transfering rigging but your problem here is UV map. It sounds like you'll have to either find a texture converter or redo the UV.
