change default amount of frames on timeline
Edpa
Hi!
We have 30 frames as default on timeline in DAZ studio. How can I change number to example 200 frames by script?
Post edited by Edpa on
Hi!
It would probably be just as simple to save a scene with the desired number of frames - you are going to have to load a file either way. However, to do it in script I think you would use
Scene.setAnimRange( new DzTimeRange( starttime , endtime ) );
Scene.setPlayRange( new DzTimeRange( starttime , endtime ) );
where time is set in DzTime units - 1/4,800 of a second. So 200 frames at 30FPS would be 200 * 4800 / 30, or 32,000 (fortunately you don't have to use new DzTime( value ) - the script will, acording to the docs, accept a bare number instead of the DzTime constructor).
Again thanks :)
No, I'm stupid :) I have to determine which is the last frame in my animation. The function getAnimRange() gives 2 digits - the initial frame and the end. How can I assign for variable number of the last frame. Help me please
Number of frames will be time interval in seconds * FPS - so FPS * endTime / 4800
Richard, hi. I did write about another things a little :)
Example -
I'll have as result - string [0, 36000] to example. I have assign for variable digit 3600. How? What I have do with this string to take this digit?
I tried to work with split and substring as in Javascript with array. But I had error
That's a DzTimeRange - once you have the animRange use the members .end and .start to get the values (those are variables, not functions, so no parentheses).
var aR = Scene.getAnimRange();
var endTime = aR.end / 4800;
var startTime = aR.begin / 4800;
Ok. I didn't know about these variables - end and begin. Thank you, Richard.
Sorry, it's start not begin - dzTimeRange is documented here http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/object_index/timerange_dz
Richard, thanks
