Transfer Files
dash2128dash2128 Posts: 725
When I point to 'files' in upper left-hand corner, and select 'open', what appears next is 'scenes'. That is where my genesis and M3 figures are located.
I just downloaded Daz4.5 into another computer. How do I transfer the files from one computer, into the other computer so that I can work on them there?
  • Richard HaseltineRichard Haseltine Posts: 102,701
    edited January 2013
    If you copy the contents of the DS and Poser content directories (the folders that are listed under the two formats headings in the Content Library pane) to the content directories you chose on your new machine everything should open, though you won't have the information needed for Smart Content then. However, if you used the default categories you can simply reimport it - right-click on the tab for the Content Library pane on the new machine, after copying the files across, and from the menu choose Content DB Maintenance. Check the reimport metadata option and click Accept.
