What is the Proper Way to Bend on X-Axis with Deformer?
![Samuel S.](https://secure.gravatar.com/avatar/e8f304a8bd3a3640fe7cacdff6f56256?&r=pg&s=100&d=https%3A%2F%2Fvanillicon.com%2Fe8f304a8bd3a3640fe7cacdff6f56256_100.png)
Hi, I have a workaround but currently looking for some advice for better out of box solution.
Bend Modifier and Deformers are working fine along Y and Z but whenever I try to
Bend on X-Axis I am getting 8 Shape. I remember it worked fine in the past.
There are multiple ways to Bend but I am wondering what am I doing wrong here with Bend Deformer?
Thanks in advance!
Images Attached:
![](https://delorean.daz3d.com/forums/uploads/thumbnails/FileUpload/1e/e69061a3a368cfe95786ee5c72587c.jpg)
1920 x 1039 - 236K
![](https://delorean.daz3d.com/forums/uploads/thumbnails/FileUpload/3b/4e5b1f6759382b7bd37b80190ffba4.jpg)
1916 x 1045 - 251K
Post edited by Samuel S. on
Never Mind following solution worked for me. I will also try this in Vertex Room. Normally I try Modifiers in Assembly room and then in Vertex Room.
Here is another side of wall and minor tweak in modifier Settings.
Adding Quick Render.
Hi friend! Glad you found out the solution, I always have issues trying to bend on any axis but Y that seems to be only the one that works for me... how did you do that?
Here are settings under Bend and Twist Modifier:
Twise Angle = 00
Bend Angle = 90
Bend Axis Angle = 270
Limits = 28-100
Axis = Y
In = X,Y,Z (all checked)
Flip = Along Major Axis checked
I think it is fine to try out in Assembly Room first before trying them in the Vertex Modeler Room. I will also add a video in near future.
Thanks will try that.
You are welcome; video showing bend deformer is also available here:
Oh cool! I have never tried before do bending in the assembly room, thanks for share this..
