Made a scene. Saved a scene. Nothing works now.
SaitoChikaraSaitoChikara Posts: 0
Title states it suimply enough.
A couple days ago, I made a character, dressed, morphed, etc. and made my render. Then I saved my scene (.daz).
I've never had issues with the 10+ characters I made before, but this new character is giving me one hell of a problem.
I've not changed any settings or directory locations, but when I load my V5 Character, NONE of the presets, morphs, wardrobe, hair and props show up!!
I get a base Genesis with the skin texture, and the shoes I had on her, but they're not even fit properly. They're a good 2' away from her feet.
How do I fix this? I don't want to loose hours of work for nothing!
  • Richard HaseltineRichard Haseltine Posts: 101,507
    edited June 2012
    Are the morphs available on the figure? Have you checked the log file for errors just after loading the scene (Help>Troubleshooting>View log, scroll to the end)? Where are your content folders stored? Which version of DS is this (Help>About DAZ Studio)?
  • SaitoChikaraSaitoChikara Posts: 0
    Daz Studio 4.0.3.47 Pro Edition (64-bit)
    Here is my log file for trying to load my ONE character/scene (and as I said, all others are working fine)
    https://docs.google.com/document/d/1ORWcCaEmnihgUSRLP0UDYfZt0xuEc9Ad9yOhVzKcFAM/edit
    I haven't uninstalled anything, or changed any files or installed anything... I haven't changed any directories or moved any files around. I made the character, went away for the weekend, then came back.
    OK, that confirms that the problem is the loss of the native geometry files. Where are your DAZ Studio Format directories, and what OS are you using?
    (Username)/Documents/Daz3D/Studio
    (Username)/Documents/Daz3D/Studio/MyLibrary
    or something really similar to that... the default.
    I'm using Windows 7 Home Premium 64-bit
    Can you check the exact paths please, and their order - if those are right I can see one potential issue. If you go to Edit>Preferences>Content Library there's a button to take you to the Content Directory Manager.
    edited June 2012
    The exact paths are:
    (Username)/My Documents/DAZ 3D/Studio
    and
    (Username)/My Documents/DAZ 3D/Studio/My Library
    Post edited by SaitoChikara on
  • fixmypcmikefixmypcmike Posts: 19,585
    The nested content folders may be your problem. Normally everything should be under "My Library". Any Data, Runtime, etc. folders which are directly under "Studio" should be merged with the ones under "My Library", and then the path ending at "Studio" should be removed from the list (and from the "Poser formats" list as well).
    So I should remove the "Studio" and make all 3 libraries point to "My Library"?
    Yes
