using GenX to enable direct morph injection into genesis character?
gabugabu Posts: 303
From my reading of various threads I gained the impression that it was possible to directly use the, say, M4 injection morphs on the genesis character if you used GenX to copy over the INJ Morphs++ M4.
So I started Genx, dragged the base M4 character to it, dragged the INJ Morphs++ to it, selected everything and transfer.
The morphs appear to have gone across. However they don't seem to work as I was expecting:
I restart Studio. I select genesis basic male, I set M4 morph to max, double click on (for example) JM_alexandre's head or body INJ but there is no change to the genesis figure at all.
What am I doing wrong? Are my basic assumptions that it is possible wrong?
  • Richard HaseltineRichard Haseltine Posts: 102,792
    First, I believe you need to process the poses through GenX if they use the standard morphs as otherwise the morph names will be wrong. Second, many character morphs do not use the standard morphs - especially for faces, where fitting clothes is not an issue - and those will need to be converted too.
  • larsmidnattlarsmidnatt Posts: 4,511
    edited June 2012
    Here is one way to do it.
    Load up M4, inject Morphs++ and then inject the face you want.
    After that Export your figure as a CR2 and load that up in GenX. (you may be able to just drag the loaded character into genx at this point, not sure).
    Then in GenX you will have a few options, but you will likely want to export M4 as a single morph, and name it appropriately. You will also want to select the "Head" category instead of "Actor".
    Now restart studio, load a NEW genesis figure and under head parameters you should see GenX. Under GenX all your head morphs should be there.
    If you exported under actor then it would be Actor>GenX
    hope that helps
    Post edited by larsmidnatt on
  • gabugabu Posts: 303
    Thanks for the advice. I have successfully converted a head morph for M4.
    I can sucessfully apply it to a 'clean' genesis character. The created morph appears in the shaping tab and acts as expected.
    However, if I load a genesis character that I have already worked on, i.e. not 'clean', there are no entries in the shaping tab at all. Even after restarting studio - I am using studio 4.0.
    Is this a limitation of the GenX transfer, that it will only work on 'clean' genesis characters, or do I need to do something extra?
    If you want to get new morphs into a Genesis from an old scene, load the scene, select Genesis, and then load Genesis from the Content Library. That will zero the character -- then press Ctrl-Z (Undo) and your character will be back, but it will now have the new morphs.
    Great! Thanks a lot for that info.
  • HatBHatB Posts: 77
    I was removing some of the old morphs I had previously created with GenX and also removed some other files under the GenX>Morph tab and now when I try to create morphs I get the following. What do I need to get back to where I can use it as before? I have tried reinstalling DAZ4 Pro, GenX, and every V4 file I think it might need.
    Create Controller
    Warning! DSF file not found for morph: V4_FBMBodyBuilder_BODY
    Warning! DSF file not found for morph: V4_PBMBreastsCleavage_BODY
    Warning! DSF file not found for morph: V4_FBMDefinition_BODY
    Warning! DSF file not found for morph: V4_PBMGenitalCrease_BODY
    Warning! DSF file not found for morph: V4_PBMHipsSize_BODY
    Warning! DSF file not found for morph: V4_PBMNailsLength_BODY
    Warning! DSF file not found for morph: V4_PBMNipples_BODY
    Warning! DSF file not found for morph: V4_FBMYoung_BODY
    Warning! DSF file not found for morph: V4_PHMBrowUp-Down_head
    Warning! DSF file not found for morph: V4_PHMCheekBonesSize_head
    Warning! DSF file not found for morph: V4_PHMCheeksDefine_head
    Warning! DSF file not found for morph: V4_PHMCheeksHigh_head
    Warning! DSF file not found for morph: V4_PHMCheeksSink_head
    Warning! DSF file not found for morph: V4_PHMChinCrease_head
    Warning! DSF file not found for morph: V4_PHMEyeFoldsHeight_head
    Warning! DSF file not found for morph: V4_PHMEyeLidsBottomInHeight_head
    Warning! DSF file not found for morph: V4_PHMEyeLidsBottomOutHeight_head
    Warning! DSF file not found for morph: V4_PHMEyeLidsHeavyBottom_head
    Warning! DSF file not found for morph: V4_PHMEyesAlmondOuter_head
    Warning! DSF file not found for morph: V4_PHMEyesHeightInner_head
    Warning! DSF file not found for morph: V4_PHMEyesHeightOuter_head
    Warning! DSF file not found for morph: V4_PHMEyesPuffyBottom_head
    Warning! DSF file not found for morph: V4_PHMEyesSize_head
    Warning! DSF file not found for morph: V4_PHMEyesWidth_head
    Warning! DSF file not found for morph: V4_PHMFaceHeart_head
    Warning! DSF file not found for morph: V4_PHMFaceLong_head
    Warning! DSF file not found for morph: V4_PHMFaceMidDepth_head
    Warning! DSF file not found for morph: V4_PHMFaceSquare_head
    Warning! DSF file not found for morph: V4_PHMJawCornerWidth_head
    Warning! DSF file not found for morph: V4_PHMJawCurve_head
    Warning! DSF file not found for morph: V4_PHMJawDefine_head
    Warning! DSF file not found for morph: V4_PHMJawHeight_head
    Warning! DSF file not found for morph: V4_PHMJawSize_head
    Warning! DSF file not found for morph: V4_PHMLashesBottomCurl_head
    Warning! DSF file not found for morph: V4_PHMLashesTopCurl_head
    Warning! DSF file not found for morph: V4_PHMLipBottomDepth_head
    Warning! DSF file not found for morph: V4_PHMLipBottomMidDefine_head
    Warning! DSF file not found for morph: V4_PHMLipBottomThickness_head
    Warning! DSF file not found for morph: V4_PHMLipBottomWidth_head
    Warning! DSF file not found for morph: V4_PHMLipTopDepth_head
    Warning! DSF file not found for morph: V4_PHMLipTopMidDefine_head
    Warning! DSF file not found for morph: V4_PHMLipTopPeak_head
    Warning! DSF file not found for morph: V4_PHMLipTopThickness_head
    Warning! DSF file not found for morph: V4_PHMLipsCurve_head
    Warning! DSF file not found for morph: V4_PHMLipsPucker_head
    Warning! DSF file not found for morph: V4_PHMMouthHeight_head
    Warning! DSF file not found for morph: V4_PHMMouthWidth_head
    Warning! DSF file not found for morph: V4_PHMNoseBridgeDepth_head
    Warning! DSF file not found for morph: V4_PHMNoseSeptumWidth_head
    Warning! DSF file not found for morph: V4_PHMNoseTipUp-Down_head
    Warning! DSF file not found for morph: V4_PHMNoseWidth_head
    Warning! DSF file not found for morph: V4_PHMNostrilsFleshSize_head
    Warning! DSF file not found for morph: V4_PHMNostrilsHeight_head
    Warning! DSF file not found for morph: V4_PHMPhiltrumDepth_head
    Warning! DSF file not found for morph: V4_PHMPhiltrumStrength_head
    Warning! DSF file not found for morph: V4_PHMHeadYoung_head
    Warning! DSF file not found for morph: V4_PBMGenitalCrease_hip
    Warning! DSF file not found for morph: V4_PBMHipsSize_hip
  • Tramp GraphicsTramp Graphics Posts: 2,412
    I have a question. I want to transfer the KV mK 2 Injected genital morph (with it's accompanying morphs) to Genesis (not a whole character) using Gen X, which I just picked up last night. What are the exact steps I need to do in order to do this?
