Can't get Carrara 64 bit to install
linuxbluelinuxblue Posts: 0
I Can't get Carrara 64 bit to install .
I have purchased Carrara Pro 8 and have installed the 32 bit of it correctly. It works fine and I have put in my serial number.
But when I click on the installer for Carrara 8, 64 bit , it hangs indefinitely.
I am a professional graphics designer. Thus the 64 bit version would be FAR preferable to be using. I am using a 64 bit computer with 8 GB of RAM. My video card or graphics card could be out of date. Not sure what version I have. I am on Windows 7.
Any thoughts?
  • 3DAGE3DAGE Posts: 3,311
    HI linuxblue
    Welcome :)
    How far does it get,... Do any dialogue boxes appear ?
    Also check the file size, it should be around 98Mb,...and perhaps try re-downloading the file from your account.
    You'll also need to download and install the "Carrara Native Content" installer, which contains the sample shaders, scenes, etc.
    Hope it helps ;)
  • linuxbluelinuxblue Posts: 0
    I'll try those things. The run box appears and then no more steps happen.
    Yes. Those things worked :) Thanks very much.
  • DartanbeckDartanbeck Posts: 21,715
    3dage, you fricken ROCK!!!
