Render camera angles
I'm trying to do some renders but I'm a bit frustrated of the angle of the camera.
In the photo bellow you can see my problem. The green line from the right it's paralel with the red lines from the left side. So I want my renders to be viewd from the same perspective. To keep the lines. How can I do that?
Sorry for my english and my lack of knowledge of terms. Thank you
2560 x 1440 - 304K
  • Richard HaseltineRichard Haseltine Posts: 102,933
    The distortion is a result of the relatively short Focal Length of your camera. Assuming this is Iray in Daz Studio one fix is to use a much longer focal length, to pull the camera back, and to place an Iray Section Plane (Create>New iray Section Plane) to remove the sections of the walls that will then be blocking your view - if you turn on Clip Lights in the Parameters pane with the plane seelcted this will not affect lighting or reflections.
  • hapciupalithapciupalit Posts: 121
    Thank you! This worked like charm.
