Anagenessis 2 vs. Anatomical Elements Question
This is a little hard to show for obvious reasons but I notice when I have a character with anatomocal elements applied AND Anagenssis 2, the AA are clearly unaffected.Is there a fix for this or is it more of a "use one or the other" thing. It's not a deal breaker for me either way. In a perfect world it would be nice to have use of both so I just thought I'd check. I normally just select the character and assumed that any skin maps attached to it would cascade down. Do I need to maybe go into surfaces and apply Anagenessis 2 specifically to the AA? That just occured to me and I'm at work.
Thanks all!
Post edited by DDCreate on
Yup, you got it. Select the surface, apply Shader NEW, and run the freebie script. You can download freebie script from here:
https://www.daz3d.com/forums/discussion/110976/n-g-s-anagenessis-ii-revolution-commercial/p1
I purchased it on Feb 6. Do I still need to run a Freebie Script? It seemed like that post was for people that bought it right away and a bug was found.
The AA I'm working with came with pro-bundles for Gen3...I guess I'm a little confused.
I was thinking, select said naughty bits in surfaces and then double click Apply AGS 2 Gen 3
The freebie script is an addon to the original product. It converts props and anatomical elements.
