Genesis figure breaks my Poser library
I'm using Poser 9 3.2 (windows xp) with DSON installed. I can load the figure into a scene and the figure itself seems to work fine however once the figure loads my Poser library becomes non functional. I'm unable to select anything in it despite how many times I click and cannot even switch library tabs (pose, props, lights, etc.). The library palette itself will open and close but everything within it stops working. This continues even after I delete the genesis figure from the scene. Only closing and restarting Poser fixes this issue....until I load the Genesis figure again.
Go to Scripts>DSON Support>Preferences and turn off the option to show the progress bar while importing. That should fix the lock up.
Wow, that worked! Thank you very much! =)
