"DAZ 3D Install Manager 1" not supported in Windows 8
AzlaAzla Posts: 0
Good Afternoon,
I was wondering if there were plans to support windows 8 with "DAZ 3D Install Manager 1"? Right now, it installs, but when you go to run it ... the process shows in the task manager, but nothing is visible ...
It would be great if Windows 8 will be supported in the next version.
    You may need to set the new default directory by Content Directory manager of ds, I think.
    have you set the path already? without setting path, cms can not find the directory.
  • AzlaAzla Posts: 0
    How do you set the path? do I need to edit the registry?
  • fixmypcmikefixmypcmike Posts: 19,612
    Try setting the compatibility mode to Win7
  • AzlaAzla Posts: 0
    That did it, Thanks! It would be awesome if that tid bit was part of the installation :) It must suck for users where the installer didn't fully install :(
  • KhoryKhory Posts: 3,854
    I have it on my win 8 lap top with no problem and no fiddling. Not sure why it isn't working for you but I don't think it is a windows 8 issue.
  • whispers65whispers65 Posts: 952
    Same here...it works fine on my Windows 8 with no adjustments.
