How to remove shader from a figure
pavsikakyjpavsikakyj Posts: 139
Greetings.
When experimenting with shaders and rendering I applied some shader to one of my character and messed up. Now her lips look unnatural and do not actually change, when I apply other presets. Is there a way to reset all properties for some surface or remove shader in other way? I tried the methode, described here: http://www.daz3d.com/forums/viewthread/22945/. But it doesen't work.
  • Richard HaseltineRichard Haseltine Posts: 102,931
    Applying a new shader prset, or a materials preset for the figure, should always replace the current shader/settings. What happens if you restart DS? Are other characters affected? Did you use the Geometry Editor tool to change surfaces or names?
  • pavsikakyjpavsikakyj Posts: 139
    I fixed the issue. Fctuallu I apllied technics described here to the whole figure. Reseted all material ans set them once more
