Released: Easy Feet - Control Dials for Genesis 3 Female(s) [commercial]
![SF-Design](https://delorean.daz3d.com/forums/uploads/userpics/729/n5LU2BSTRG1KX.jpg)
https://www.daz3d.com/easy-feet-for-genesis-3-female-s
Get complete control over the feet of all Genesis 3 Female based characters.
This Add On for Genesis 3 Female based characters comes with 187 additional control dials for the feet.
There are controls for the entire left foot and right foot, both feet, all toes (left and right foot) separately (toe node one and two) or together, the heel and metatarsals. Included are also custom morphs to adjust the feet and for the nail length (each nail separately or all together).
Make the feet and/or toes longer, shorter, wider, smaller, thinner, thicker, bend, rotate and twist them. Each toe can be controlled seperately as well as the heels and metatarsals.
You can achieve extreme poses with these controls. Scripts to disable/enable the limits are included. All controls are set to pose or shape modifier so that you can save presets if you like.
This control add on is very versatile. Whenever you are in need of more control of the Genesis 3 Female(s) feet, this one is right for you.
The controls are located in the main actor parameters and as alias controls in each foot and toe nodes for convenience.
![](https://delorean.daz3d.com/forums/uploads/thumbnails/FileUpload/0e/854e6bb55fa91547479749e09599d2.jpg)
![](https://delorean.daz3d.com/forums/uploads/thumbnails/FileUpload/53/df505e6b304c55a4196ff8fbb40d3a.jpg)
![](https://delorean.daz3d.com/forums/uploads/thumbnails/FileUpload/5d/b46aa24e855b7c97fe8c674e3e7a6c.jpg)
![](https://delorean.daz3d.com/forums/uploads/thumbnails/FileUpload/cf/a9fa4487abebbe1b434648120aa858.jpg)
Wants.
hehe :) you will be able to get it soon![laugh laugh](https://www.daz3d.com/forums/plugins/ckeditor/js/ckeditor/plugins/smiley/images/teeth_smile.png)
thx!
very welcome :)
Has been released!
Had a slight issue with this. It seems that when I dial the Dorsum Shape control, it messes up the character's teeth. Any ideas?
Thanks for telling me. I will check this, and if there is a problem with that dorsum an update will be created of course.
Does this happen when no other morphs (from other packs etc.) are dialed in , so only the base character with the dorsum morph?
Which character did it happen, Genesis 3 Female base, or any other only or all?
Please let me know this (you can send me also a PM here)
ohhhh yeah. This did not happen when I created the product and also not in the Daz testing.
Seems that something has changed there, maybe there was a Genesis 3 Female Update, that broke the morphs. Actually all 3 morphs are affected.
However, I will recreate the morphs and fix this. THe update process will take a little while since it is going through the whole DAZ QAV process.
Please be patient and sorry for the inconvenience. Once the update is live I will let you know here, but you will be informed in DIM as well.
Thanks for the Heads up about this issue.
if you need it urgent I can send you the 3 affected morph updated by mail too. Please tell me by PM then.
