Cell Block B [Commercial]
![retrodevil](https://delorean.daz3d.com/forums/uploads/userpics/900/n86GUYS0LUMAJ.jpg)
Cell Block B is OUT NOW!!
Check it out in the Daz3D Store
Cell Block B known as the Bird Cage houses some of the most dangerous criminals around. Due to over-crowding a cage has been erected in the centre of the room to allow for additional inmates.
This cell block scene consists of one large room, entered in by a small corridor and surrounded by 12 separate cells. Each cell has opening doors with opening hatches and lockable bolts, a bed and a toilet. Two staircase's lead the way to a walkway and access to the cells on the upper floor.
The cage houses two more beds and has an opening gate. The cage and beds are separate prop's and can be moved or removed it you wish.
All of the props can also be loaded individually for use in other scenes.
Finally users of Iray can choose to have the lights on or off with three areas of illumination (Main Room, Cells and Entrance Corridor). Lighting options not available for 3Delight.
I like the cage.
Thank you Miss Bad Wolf :D
