mcjexportcamtoblender - Export Animated Daz Studio cameras to Blender
mCasualmCasual Posts: 4,607
edited December 2014 in Freebies
manual and download here :
https://sites.google.com/site/mcasualsdazscripts/mcjexportcamtoblender-ds1-2-3-4
History
June 26th 2014 - (re) fixed it to work with Blender 2.71 and previous
Dec 22, 2013 - changed change-frame operand which did not work with blender 2.69
feb. 14th 2013 - Changed the Blender/Studio scaling factor from 50 to 100
dec 17th 2011 - Release
As you may know, you can export a scene from Daz Studio as an .obj file.
( also see mcjGeoSender and mcjTeleBlender )
Later, you can import it in Blender and use all its nifty services, notably the awesome Cycles renderer.
this free script mcjexportcamtoblender lets you export animated cameras from Daz Studio as a "Blender Python Script".
In Blender, you create/select a camera,
run the Blender Python Script in the Text Editor panel,
and it applies the animation to the camera, starting at the current frame.
1st animated image
the static/still Daz studio scene was exported to Blender using mcjTeleblender
( a new version of mcjTeleblender with proper scaling factor ( 1%) will be posted incessantly )
the Daz Studio camera animation was exported using mcjexportcamtoblender
the camera animation was imported in blender
rendered in Blender cycles
2nd animated image
same scene hardware-rendered in Daz Studio
if you refresh this page, the two gifs should be in sync
it's a Moebius strip camera path ! the legend goes that .... what was it called the something experiment
the Philadelphia experiment : http://en.wikipedia.org/wiki/Philadelphia_Experiment
note that mcjTeleblender can render animated Daz Studio scenes in Blender
a Blender to Daz Studio camera exporter will be published very soon
320 x 180 - 659K
320 x 180 - 538K
Post edited by mCasual on
  • mCasualmCasual Posts: 4,607
    - Update - Update - Update - Update - Update - Update - Update -
    the python script generated by my Daz Script was not compatible with new versions of Blender ( 2.69 )
    History
    version 3 Dec 22, 2013 changed change-frame operand which did not work with blender 2.69
    Version 2 Feb 14, 2013 ?
    Version 1 Dec 17, 2011 release
    edited June 2014
    - UPDATE - UPDATE - UPDATE - UPDATE - UPDATE - UPDATE - UPDATE -
    example
    you set a scene in Daz Studio
    you animate a camera
    you use this script to export the camera animation as a file ( a blender python script in fact )
    you use mcjTeleblender to export and "cook" your scene so it's ready to render in
    Blender with the Cycles renderer, ( which is like Octane and LuxRender )
    you select or create a camera in Blender's scene
    you load and run the camera animation file
    you're ready to render this static scene from the point of view of the animated camera
    if your daz studio scene is animated, then you'd have to use mcjTeleblender
  • nakamuram002nakamuram002 Posts: 792
    Presently, mcjTeleblender exports only one camera to Blender. It would be nice if it could export all camera in a scene to Blender.
    * * Update * ** * Update * ** * Update * ** * Update * *
    the new version has a "scale" parameter
    so if you exported a scene, for example, using mcjTeleBlender
    with a non standard scale factor of 10%
    you can export animated cameras with the same scale
    it all fits ( puttin on the ritz )
    480 x 360 - 795K
  • ajd_at_072df9a27dajd_at_072df9a27d Posts: 60
    Test ok
    ideal for dynamic clothing for figures in Blender, it is necessary to change the scale (5) to work wonders.
    Thanks Casual
