Posing Handles Showing
spmwcspmwc Posts: 124
I have the Malaika outfit. I really like the outfit but when I load the skirt the Posing handles appear in the window. I am unable to remove them. They show up when I Render the scene and I believe they are interfering when I try to send Vicky5 wearing the outfit to Bryce7. Does anyone know how to remove these handles. They are for the front, back and sides. Thanx for the help!!!:roll:
    edited February 2013
    Hi,,I think,, you used Malaika outfit for genesis with "auto-fit".
    then sometimes these clothings and props have handle,, but it can not be useful
    when you wear it on genesis by auto-fit.
    if the wear set has poze file to invisilbe handle?
    I think,, usually it work .( edit,,,,ah,, sorry I understand,, after use auto-fit,, the ghost rig for handle lost away,
    so the poze file which invisible (hide or show) handle node, can not work.)
    And , the handle has individual surface group.
    if the handle has surface group,,,, it is easy to transparent.
    select the handle by sufface selection tool,
    then go to surface tab, (now selecting the handle surface group only)
    select "opacity" property, then turn the value to "zero".
    it can not been visible anymore.
    then,, if the handle has not individual surface group,,
    eg when you select handle,, it is included in other surface group,,
    you may need to make new surface group by poligon group editor.
    then set opacity for the handle surface gorup
    if you do not know how to use it,, please ask here again. :)
    814 x 519 - 76K
    Post edited by kitakoredaz on
  • spmwcspmwc Posts: 124
    Thank you Kitakoredaz, I did as you suggested and turned the opacity to 0 under the surface tab and the handles disappeared. ;-)
