Projector Screen Display (Canvas)
I have purchased the Multi-Purpose Meeting Room which has a projector & canvas in the scene. I am trying to figure out how to insert my png or jpeg photos so that i can display them. Kind of like a powerpoint presentation. Any ideas?
Any help would be greatly appreciated. Thanks in advance.
  • Richard HaseltineRichard Haseltine Posts: 102,931
    Essentially, you need to use the Edit tab of the Surfaces pane to assign a map (you slide) to the screen (or in Iray you could use a Decal node - Create>New Iray Decal Node) which may make it look more like a projection). To assign a map, select the surface (for example, by clicking with the Surface Selection Tool) then in the Surfaces pane click the mini-thumbnail or triangle to the left of the Diffuse/Base Colour, then from the menu that opens select Browse and load your image.
