Carrara 8.5 and ZB4r5
richard.fortier_668619e441
1. Could you confirm to me that Goz plugin will work fine with Zbrush 4 rev5 and Carrara 8.5 pro.
Its is not working now with carrarra pro 8.1
2. The link with Carrarra 8 pro do not work in the Goz ZB page. It is not good for the Daz image. I joint a screen capture.
Thanks!
922 x 1038 - 219K
The Go-Z plug-in does not work for me in 8.5 beta with 4.5 Zbrush
Hi ricor :)
Carrara 8.5 is still in "beta" development,. which means that it''s not a release version , and that not all of the existing plugins will work in 8.5 at this time.
If the HTML Link on the Pixologic web site is not working,.. then that's something which needs to be fixed, but i've no idea whether the problem needs to be fixed by Pixologic, or Daz3D,..
As far as I'm aware,. The GOZ plugin for C8 pro,. works in C8 Pro.
Hope it helps :)
Hope it helps :)
Go-Z works with Lightwave in their latest package, so my guess there is a problem with Carrara 8.5 beta.
