Warning: Wrong type of node for joint parameter
Granville
I have a product that I got from a vendor at rendo called old courtyard. It is absolutely beautiful when rendered. I am able to load all the cr2 an even the entire pz3 scene into DS3. But I can not load either successfully into DS4.5. The cr2s load and are listed in the scene tab, but they are no where to be found. When loading I repeated get the error
This happens occasionally in 4.5: scenes and cr2s that loaded fine in DS3 load blank. Can anyone advise me how to fix these models?
Do you have a link to the product?
Load them in DS3; make any adjustments for surfaces etc. and save as DAZ scene files. You should be able to open them in DS4.5 using the Scene files.
In DS4 select it in the scene tab, then in the Parameters tab check for any dials that say "Empty_Range", if you do find any then you will have to change them as DS4 doesn't like dials like that, especially scale dials.
Here is the link to the product and the full detail of the log file
http://www.renderosity.com/mod/bcs/old-courtyard/79411/
Reading b2.obj
Warning: Wrong type of node for joint parameter on line 365 in E:/Poser Big Content/runtime/libraries/Character/Environments/France/Courtyard Romance/b2.cr2
Warning: Wrong type of node for joint parameter on line 390 in E:/Poser Big Content/runtime/libraries/Character/Environments/France/Courtyard Romance/b2.cr2
Warning: Wrong type of node for joint parameter on line 416 in E:/Poser Big Content/runtime/libraries/Character/Environments/France/Courtyard Romance/b2.cr2
Warning: Wrong type of node for joint parameter on line 458 in E:/Poser Big Content/runtime/libraries/Character/Environments/France/Courtyard Romance/b2.cr2
No bone found for otherActor on line 2329 in E:/Poser Big Content/runtime/libraries/Character/Environments/France/Courtyard Romance/b2.cr2
Thanks for the help.
