how to change cloud location?
I moved most of Daz library directory to custom location
but not able to fine where to change cloud data download directory. (My daz install manager download thing in the folder I want fine, It's Daz stuidio Install menu issue.)
It still install things at original my documents folder : Documents\DAZ 3D\Studio\My Daz Connect Library\data\cloud\
Anyone knows how to change setting?
  • Richard HaseltineRichard Haseltine Posts: 101,010
    In DS, Edit>Preferences>Content tab, click the Content Directory Manager, select the current directory name and select Modify (you can have onyl one, though the old one will still be read if you make it a standard content directory).
  • @Richard Haseltine I followed your direction a few months back and it worked like a charm I upgraded my 2nd hard drive to a larger HD and replaced my C drive with the old 2nd HD due to it being bigger so after installing Daz central and installing Daz Studio it made all the old folders that I had on my 2nd HD before the wipe and windows reinstall so Daz holds that info on their website
  • If you replaced the C: drive then that will have reset everything. If you lost the database then you will need to reinstall the Connect products, but the files are still theer and so instalaltion should - in theory - be relatively quick.
