Carrara 8.5.132 or Carrara 8.5.172
RealtimeRealtime Posts: 95
Just a quick question.
All that I have available to me in my "available downloads" is Build Carrara Pro 8.5.132.
However, I see references to in the forum to build Carrara Pro 8.5.172.
What gives?
Shouldn't this beta be available for download? Did I miss something along the way?
  • 3DAGE3DAGE Posts: 3,311
    HI Realtime :)
    If you've bought Carrara 8,. then you should also have the 8.5 beta version available in your account.
    If it' not,..you should contact daz support to get them to add it to your account.
    one thing to try before that is,.. resetting the download for Carrara 8 from your account / order history ,. just to see if the 8.5 beta version shows up.
  • RealtimeRealtime Posts: 95
    Thank you.
    Yes - I've purchase every upgrade from 5 pro.
    I'll follow up and check as you have advied.
  • StezzaStezza Posts: 8,206
    if you use products from 3D Universe then don't use .172
    if you can get it use .149 so you can use the rabbit and cows with all their morphs :)
