mcjSuperLathe - Spline-based morph and prop creation - 2019 SAFETY Update
mCasualmCasual Posts: 4,607
edited March 2019 in Freebies
download --> https://sites.google.com/site/mcasualsdazscripts2/mcjsuperlathe
Version History
March 1st 2019 - Safer :refuses to build a morph on subdivided surfaces which rendered scene files un-loadable
2012 Jun 25 06:48 v0.07 the DS3/DS4 script has d-Form handling functionality
2012 Jun 21 06:41 v0.06 lFor DS1 and 2 ( briefly tested on DS1.8) and important patch to the DS3/4 version
2012 Jun 9 23:58 v 0.00 initial release
for the impatients (which would include me ) , the unfinished/beta version of mcjSuperlathe
as you could see in the old forum's teaser thread, it can already do a lot of neat tricks
here's a few teaser pics
and a screenshot of the UI
the idea is: using your mouse, you draw a curve, this curve is then use to deform existing objects or figures
and it keeps the functionality offered by mcjLathe
you know the maids in anime look happy but it must be a very stressful job
yay 11:57 i made it before the midnight deadline !!!
600 x 337 - 17K
600 x 600 - 137K
600 x 468 - 93K
600 x 412 - 43K
600 x 480 - 43K
Post edited by mCasual on
«1
    How long between the beta and final versions? :cheese:
  • mCasualmCasual Posts: 4,607
    we're talking years
    kidding
    there's even a faint possibility that today's version will be complete and finalized
    600 x 600 - 343K
  • ThatGuyThatGuy Posts: 797
    this is just awesome! Thanks for putting an end to the teasing ;-P and letting us have at it. I will stay up past my bedtime until I see you post its availability tonite.
    edited June 2012
    ~ News Update ~
    our teams of mad scientists announced that the scale-effect, which was damaged during the making of the bend-effect, has been repaired
    delivery date deadline is midnight eastern North American time zone
    also seen here the shear effect
    and the presser effect
    and the twist effect
    600 x 600 - 42K
    600 x 480 - 95K
    600 x 480 - 48K
    600 x 480 - 27K
    600 x 480 - 47K
    I was kidding about staying past my bedtime...it was only a joke so I hope you did not feel pressured or put in a spot in any way. :red: I appreciate all the efforts and hard work you put into making all your scripts and props you give the community :kiss:
    edited June 2012
    ok good, 1 hour from now i wont feel as guilty for not meeting the midnight deadline :)
    it's going well so far
    but, there's the manual to write too, so 1 hour is a bit short i guess :)
    unrelated image
    256 x 256 - 232K
    edited June 2012
    version 0.00 has arived
    600 x 400 - 48K
    600 x 429 - 28K
    600 x 600 - 101K
    600 x 487 - 137K
    This looks like a fair ride. lol
    256 x 256 - 232K
    edited June 2012
    ~ SuperLathe ~ News ~ ~ SuperLathe ~ News ~ ~ SuperLathe ~ News ~ ~ SuperLathe ~ News ~
    so far the scale / shear / twist / press deformers in mcjSuperLathe version 0.05
    only work well when the object being deformed is not moved / rotated / scaled from its load-time state
    The News is that, once that's fixed, ve're probably be at the Version 1.0, the real release.
    the first image here ( is a bit of a monster ) shows how the gizmo ( the panel that acts a bit like a lathe tool ) only affects the area it is projected unto ( i'm so lucky i dont have an English teacher witness my sentences ).
    600 x 600 - 50K
    lol @ english teacher bit. Who knew you were a comedian?! :lol:
    I had a go at your Superlathe last night and I must be using it wrong because I find the regular mclathe version so much easier to understand. I know Superlathe is supposed to be the all-in-one. I didn't see the drawing board that mclathe has for me to create curves, so I just messed around with twist, bend, shear, etc. Maybe I'm just technically challenged :roll: I'll have another go at it tonite and see if my understanding improves any.
    edited June 2012
    oops no drawing board, that's a serioud problem, i'll try to understand why and fix it, it's supposed to look as shown below.
    mcjLathe could create props, mcjSoperLathe can deform existing props/figures. i'm thinking i may add the ability to create extrusions, like for example ribbed columns and gears etc etc
    600 x 600 - 28K
    600 x 431 - 46K
    Sorry it seems I was confused when I said the superlathe did not have a drawing board for me. It is there. It just did not have the blue dots and red dot initially unless I load a previously created curve from mcjlathe.
  • SkirikiSkiriki Posts: 4,976
    Um, does this work in 4.5, any idea? Just before I go and install it, that's all. :)
    oh then you possibly have one of the first versions
    the recent versions contain a folder with 10 curves,
    when the program starts, it tries to load one of those curves,
    so if you use an old version folder and the curves are not there ... my fault sorry :)
    for your trouble you win a pic of a rich maid
    369 x 362 - 24K
    edited June 2012
    i'll test it right now in daz studio 4 pro
    ( i build it using studio 3 )
    it takes so long to start ! studio 4 i mean, we're taking minutes
    yes it works
    built in DS4
    this was a straight primitives-cylinder
    rendered in Blender/cycles
    oh and you'll probably get an error message the first time you run it, just run in again
    600 x 600 - 60K
    SQUEE! Cool! :)
    cool! I ain't never seen a maid with jewelry like that before.
    edited June 2012
    ~ News Flash ~ News Flash ~ News Flash ~ News Flash ~ News Flash ~ News Flash ~
    mcjSuperLathe 1.0 will include a brand new deformer named gear or Cam or Cookie
    which lets you mold objects to shapes like gears, cams, cookies, stars, and other toothed things
    so, you'll simply draw 1 tooth, select the number of teeth, and press a button
    'magin' the possibilities
    600 x 600 - 55K
    600 x 600 - 41K
    600 x 600 - 45K
    600 x 600 - 413K
    600 x 600 - 399K
    OMG....that is so cool! So now I gotta download 1.0...I just downloaded .05 last night. I like the additional deformers. Thanks!
  • bighbigh Posts: 8,147
    slick stuff
    v1.0 is the end of the journey we're not there yet, but i will try to post version 0.6 tonight or tomorrow, which includes updating the manual/web page. Version 0.6 should include that new cookie/gears effect.
    and a random image, unrelated , lets see
    600 x 502 - 16K
    oh, I jumped the gun, eh? LOL...I thought you meant V 1.0 is available now with the new deformers. Silly me.
    edited June 2012
    bigh said:
    slick stuff
    t'was easier than expected to program, and the results were surprising too :)
    if i can finish this, then the dynamic hair thing, i'll have time to make my stupid non-technical videos , yay :)
    unrelated pic, Aiko riding a roomba robot-vacuum cleaner
    320 x 180 - 133K
    edited June 2012
    note: what's shown below is what will be in the not-yet posted version 0.6
    1 - a radial shear deformer changes a torus into a sort of tire
    2 - a radial scale deformer
    3 - lets call it an axial, scale deformer,
    4 - a symmetric / axial / shear effect applied to a cube
    5 - a positive / axial / shear effect applied to a cube
    you can see it's a scale effect because the shape retains come characteristics of a cube.
    the new thing in version 0.6 will be, the object being deformed as well as the "gizmo" can be positioned, scaled, rotated any way;
    so you could deform a tree branch which is not pointing along the usual axis
    600 x 337 - 33K
    600 x 337 - 32K
    600 x 337 - 28K
    600 x 337 - 30K
    600 x 337 - 29K
    then the dynamic hair thing - what that all about :coolsmile:
    Everything looks fantastic so far! I'm holding out for 1.0, personally. ;)
    edited June 2012
    t'was in the old forum in May, i started writing a script to animate hair like pigtails and ponytails
    it will make them hang down according to gravity,
    and prevent them from entering the shoulders and face,
    it should also make them swing and sway, like a hair simulation ,
    way faster than a real hair simulation, but less physically accurate
    at first the system will work specifically for the Darling hair from
    http://www.daz3d.com/shop/hair/long/aiko-3-hair-pack/
    200 x 400 - 419K
    one point zero has such a nice ring to it :)
    Indeed it does. lol
    edited June 2012
    the news is that the mcjSuperLathe's 6 effects
    "Scale", "Twist", "Shear", "Bend", "Press", "Scale-Cam"
    have almost reached completion, and version 0.6 is around the corner
    picture 1
    the "press" deformer projects the object on a wall having the shape of the curve
    a thick object like a torus/donut would become a flat ring/band if the Press / Radial deformer was used
    picture 2
    mcjSuperlathe will let you "harden" segments of your curves.
    this makes the segment of the curve a straight line
    This was added in part to help the creation of gears
    Picture 3
    a gear which would be difficult to achieve without
    this new segment hardening
    600 x 600 - 69K
    600 x 600 - 51K
    600 x 600 - 63K
