JCM , Clothing and Property Editor
bloodboybloodboy Posts: 68
I´m just working on my First Clothing for Genesis ..
It´s an Apron .. Everything works fine ..
Now I´m working on some JCM ..
For example .. If Genesis is Bending RightThigh ..
The Apron should wrap around .. Genesis Thigh when Genesis is bending the RightThigh..
I just did the Morph and it worked very well .. everything is worked up well ..
Now I want to set ip up int the Property Editor ..
But I don´t know what I have to link together ..
This is what I want .. IF GENESIS IS BENDING THE RIGHT THIGH ..
THE JCM FROM THE APRON SHOULD APPLY
Any suggestions how I have to link it ??
Thanks a lot
    Set this up with the apron - bend the apron#s thigh, set the morph, and from the Property Editor pane menu (click the button in the top corner, or right-click the tab) select ERC Freeze..., select teh Apron as the figure, the thigh as the control node, and the bend as the property, then make sure that the morph is selected in the scrolling property list at the bottom and click Accept. That should set the link up for you.
  • bloodboybloodboy Posts: 68
    Awesome .. Thanks a lot .. it works ...
