Ambient colour bug.
Anyone else find that sometimes when you load a saved scene some of the ambient colours appear as though they are white with the intensity cranked to 100 when you render and that all the lights have their intensity set at 200% even though when you look at the settings they all appear to be normal. When you close Daz Studio and re-open and reload the scene everything is exactly the way it is supposed to be. This has happened to me a few times now. My version is 4.5.1.6.
I haven't seen it in ver 4.5.1.56, but have a couple of times in earlier versions. You may want to update...
But wouldn't 4.5.1.6 be newer than 4.5.1.56?
No, this has caused confusion for many people. 56 is larger than 6, so 4.5.1.56 is newer.
Hi @ghastlycomic,
The most recent version is version 4.5.1.56. It was released in early January http://www.daz3d.com/forums/discussion/14562/.
Hope that helps :)
Wow... that is a very confusing number scheme. Thanks!
Yes, it goes against the old tried and true DOS alphanumeric way of listing file names.
That said, I believe they are considering everything after the last (.) as a whole number, and not individual numeric characters, which is what you are probably used to.
They are four whole numbers separated by dots, like IP addresses. If they were decimals there could be only the one dot.
Please refer to the old post if people want to pick up this conversation. It was covered well and in depth so starting from scratch here on the whys and hows of versioning doesn't make sense. I don't have the link atm unfortunately.
