Rendering Carrara ( and Poser ) Scenes using Blender Cycles --- Some time-saving tools !
mCasualmCasual Posts: 4,607
edited November 2013 in Freebies
this way :
https://sites.google.com/site/mcasualsdazscripts2/mcjblendbotspecial
it can also be used for Poser Scenes, although there's caveats
https://sites.google.com/site/mcasualsdazscripts3/teleblendforposer
history:
Nov 3 2013 corrected mcjBlendBotForCarrara which was now unable to invoke the addCamera function in the mcjBlendBot module
Introduction
On my site you can find a script which lets Daz Studio users export
scenes and render them in Blender, including the use of the Blender Cycles renderer
the Daz script exports the scene as an .obj file and creates a python script which is then
used by Blender to load the .obj (scene) and do all the tedious chores needed to make
the scene render correctly.
Since Carrara users also want to render scenes in Blender/Cycles i wrote a blender-python script
which uses the same services as the Daz Studio version : a kit of blender python scripts named mcjBlendBot )
Later in 2013 i'll probably improve on this since the results are not as good as the Daz Studio version
1280 x 720 - 108K
1118 x 654 - 127K
Post edited by mCasual on
  • 3dcal3dcal Posts: 178
    Jacques,
    thanks so much for this!
    I will try it ASAP. =)
  • 3dtoday3dtoday Posts: 0
    Casual you are the KING of programmers!
    thanks
  • 3drendero3drendero Posts: 2,024
    Thank you for your efforts.
    Tried a few quick model exports to obj, dae and 3ds, none worked well with materials, only obj seemed to work, but as you said, lots of extra tweaking is needed.
    What Carrara settings for the obj export did you use?
    Can't wait for the updated version!
  • mCasualmCasual Posts: 4,607
    update update update update update update update update update update
    also Poser instructions
    don't know if it's a change in Blender but the mcjBlendBotForCarrara module
    was not able to do the last step of it's list of tasks which was the creation of a camera
    this was fixed today
    so you'd need to download the new zip package
    and unzip it in your blender scripts/modules folder
    new mcjTeleblender https://sites.google.com/site/mcasualsdazscripts3/mcjteleblender2
    old mcjTeleblender https://sites.google.com/site/mcasualsdazscripts/mcjteleblender-for-ds1-2-3-4
    In other news you can use the mcjBlendBotForCarrara module to import Poser scenes
    it's explained here : https://sites.google.com/site/mcasualsdazscripts3/teleblendforposer
  • English BobEnglish Bob Posts: 113
    There's a Poser Python script available here: http://3doutlaw.com/home/?page_id=631&did=17 which is written to automate map gathering and be used with mjcTeleBlender.
    I haven't tried it myself due to being a Blender dunce :) but it may offer the solution you (or rather, your Poser using followers) were hoping for?
    nice !
    i'll put a link to it on the teleblender pages
    recent render of a daz studio scene
    1920 x 1200 - 493K
    edited October 2015
    GOOD NEWS
    Today October 31st 2015 i did succesfull tests using the mcjBlendBotForCarrara included in version 3 of mcjBlendBot
    my tests for https://sites.google.com/site/mcasualsdazscripts4/mcjteleblender3
    For Older Versions Of Blender maybe you'll have to use --->  mcjteleblender-for-ds1-2-3-4
    The instructions are still here https://sites.google.com/site/mcasualsdazscripts2/mcjblendbotspecial
    Important Note : i believe this can save you time, but it's not the paradise to use and figure !!!
    1920 x 1080 - 198K
  • hey, there are lot of broken images on your site.
    So it is not possible to read all.
    Does ist work with DS 4.X too?
    You only tell us about version 1.X
    edited August 2016
    UPDATE UPDATE UPDATE
    mcjBlendBotForCarrara with Blender 2.77 still works BUT there's a problem
    in a nutshell, there's a step of the import process called "Gamma-Fix"
    when the .obj/.mtl scene comes from carrara, the mechanism i put in place to avoid "gamma-fixing" materials more than once fails
    since the gamma-fix has the effect of darkening the material colors, you end up with figures with some tan skin and some black skin
    the solution is to disable that step
    if you wanted to fix your version "manually", you could open your copy of C:\Program Files\Blender Foundation\Blender\2.77\scripts\modules\mcjBlendBotForCarrara.py
    and delete  the line that reads mcjGammaFix.fixObjectsExcept( aObjectsBefore )
    But i also uploaded a new version of the mcjBlendBot kit of scripts - which includes this modified mcjBlendBotForCarrara.py
    notes: the version for Daz Studio relies on the daz-script mcjTeleBlender for things like transparencies
    mcjBlendBotForCarrara doesn't have that extra help so you still have to manually select the corneas of your figures and change their material to "BSDF Transparent"
    mcjBlendBotForCarrara.py is in V.16 of mcjBlendBot here --> https://sites.google.com/site/mcasualsdazscripts4/mcjteleblender3
    the manual for mcjBlendBot for Carrara and poser is here --> https://sites.google.com/site/mcasualsdazscripts2/mcjblendbotspecial
    1920 x 1080 - 3M
    edited August 2016
    good news: if you apply the glass shaders like the Crystal shader which comes with the default carrara content
    it correctly becomes a transparent material in Blender Cycles after the import by mcjBlendBotForCarrara
    so you can apply a shader like that to your figures corneas and to things like ... glass
    dont forget to get the new version of mcjBlendBotForCarrara posted on 8/9/2016
