Could I change wireframe color?
Hello,
I'm a newbie.
I started using Daz Studio Pro from a month ago.
I'd like to change the wireframe's color on that.
I try to make a face from a photo recently.
But, it's difficult.
Because the wireframe is white and the photo is bright.
So, it's bad visibility.
Could I change color of the wireframe?
Thank you for reading.
  • Richard HaseltineRichard Haseltine Posts: 102,910
    The wireframe takes its colour from the Diffuse collour or Base colour, set in the Surfaces pane. So, open the Surfaces pane, go to the Editor tab, click the name of the figure in the list down the left, click part of the colour selector for Diffuse Color or Base Color (depending on shader) to open a colour picker and choose the value you want. To revert when done reapply the materials preset (or, in most cases, just reset the colour to white).
  • The wireframe takes its colour from the Diffuse collour or Base colour, set in the Surfaces pane. So, open the Surfaces pane, go to the Editor tab, click the name of the figure in the list down the left, click part of the colour selector for Diffuse Color or Base Color (depending on shader) to open a colour picker and choose the value you want. To revert when done reapply the materials preset (or, in most cases, just reset the colour to white).
    Hello,
    Thank you so much Richard!
    It worked.
    I am really helped.
    Thank you for your help.
