Octagon and Oval frames (new freebie)
Eden EvergreenEden Evergreen Posts: 326
edited March 2013 in Freebies
Eden Evergreen Presents:
Two frames, shaped as Octagon and "Oval" (or Elipse)
Now there are two more picture frame / mirror / window options for decorating the walls of your indoor scenes.
Each has detailing in the frame - not flat, but sculpted in a manner similar to many frames one sees around pictures on walls out in the "real" world.
Included:
* 1 Octagon frame .obj
* 1 "Oval" [Elipse] frame .obj
* 1 Octagon frame .pp2
* 1 "Oval" [Elipse] frame .pp2
* 1 Octagon Frame UV map
* 1 "Oval" [Elipse] frame UV map
UV maps are in the "Documents" folder with the ReadMe.
* No textures included, only the UV maps*
Enjoy. :)
Uploaded to both ShareCG and Renderosity...
http://www.sharecg.com/v/67868/view/11/Poser/Octagon-and-Oval-Frames
http://www.renderosity.com/mod/freestuff/details.php?item_id=70927
200 x 191 - 13K
Post edited by Eden Evergreen on
  • Lord GanthorLord Ganthor Posts: 592
    I can't say that I've ever had a use for oval or octagon shaped frames...until now. I can think of a couple of dozen places to use these right off the bat. Thank you very much for these. Now, where did I put that picture of my grandmother...
  • Eden EvergreenEden Evergreen Posts: 326
    You're welcome. :)
    I thought a little variety might be nice... I see rectangular frames from time to time, but had never seen either of these shapes.
    Hopefully you and others will find them useful. :)
  • JaderailJaderail Posts: 0
    edited March 2013
    Oh, nice. And they will work very well as mirrors with the right surface settings.
    Post edited by Jaderail on
    Yes, with the right reflective settings, both should be able to serve as mirrors.
    Also, if you have [stained] glass textures, you can make the back transparent and use them to fill a hole (created by transparency) in a wall...
