[Tutorial] From Map Transfer to Material Presets
L'AdairL'Adair Posts: 9,479
edited January 2018 in Art Studio
A step-by-step tutorial on how to use the DAZ "7" female figures' materials, with their unique UVs, on the new Genesis 8 Female.
This tutorial will show you exactly how to use the Map Transfer utility, introduce you to a free graphics utility I find invaluable and show you how to use a couple of very handy batch processing features of that program, walk you through the tedious process of changing all the correct maps for a figure, as well as the tedious process of saving your new material presets.
However, since this tutorial was published, RedzStudio released Genesis 3 Character UVs for Genesis 8 Female and Genesis 3 Character UVs for Genesis 8 Male. These products provide the DAZ "7" figures' unique UVs for Genesis 8, making the need to use the Map Transfer on the materials no longer necessary. I highly recommend both. If you don't have them yet and money is an issue, I urge you to add them to your wishlist, to pick up the next time their sale price fits your budget.
If you cannot yet afford these products, you can still use the materials by following this tutorial for the specific figure you wish to transfer.
Even if you have/get the RedzStudio products, if you're relatively new to Daz Studio, I believe following along with this tutorial will help you understand Daz Studio a little better: The more you know about Daz Studio, the easier it will be to learn other features you've yet to use. Understanding how to save material presets, for example, will help you with the dialog for saving any of the other presets.
Post edited by L'Adair on
«1
  • L'AdairL'Adair Posts: 9,479
    edited January 2018
    Genesis 8 Female (G8F) is being advertised as the most compatible Genesis yet. I have to agree. Among other things, G8F and Genesis 3 Female (G3F) share the same UVs. It is a simple matter to apply most G3F character material presets to G8F. However, all of the Daz "7" figures have their own, unique UVs which G8F does not have access to—at this time, anyway. Edit: RedzStudio has since released products for both the male and female Daz "7" figure UVs for their corresponding gender. See links above, in the OP.
    The answer to using those materials on G8F is the Map Transfer utility. Yet there is vitually no official documentation on how to use this very useful tool, and most of what you can find via Google is old, and sometimes more confusing than helpful.
    Rune vs Rune, by L'Adair
    One of these models is Rune 7, the other is Genesis 8 Female. I followed Redz tutorial from the Morphs from G3 to G8 to create a shape morph of Rune for G8F and the Map Transfer utility to convert Rune's materials and created a complete set of presets from those materials. Pretty much the same steps as this tutorial. (I actually started the tutorial with Rune as the example, then decided more people were likely to have V7 than Rune 7.)
    The Map Transfer utility is simple and easy to use. So simple, I think, that once a person knows how to use it, they forget how intimidating it can be to one wondering how in the bleep to set those grayed-out options! This tutorial provides simplified step-by-step instructions that will have newbies and not-so-newbies alike feeling like a Map Transfer expert in short order.
    By the end of this tutorial, you will have a set of usable material presets* for the new Genesis 8 Female (G8F). I will be using Victoria 7 for this tutorial, but it doesn't matter which "7" female you use, it's the same proceedure. (Instructions are for computers running a Windows operating system as I don't have a Mac.)
    This tutorial is broken up into parts, chapters if you like, focusing on specific steps to 1) convert the materials from one figure to another when the UVs are different, 2) apply the converted materials to the target figure, and 3) create presets for easy access to these materials for the target figure. These "chapters" are presented in separate comments below, making it easy to share a link to a specific chapter, or bookmark where you left off. There are also "Intermission" chapters to give you a mental breather, where I share some of my "secrets" to making all of this easier and faster.
    Part One: The Map Transfer Utility
    Intermission
    Part Two: From Maps to Model
    Intermission
    Part Three: From Model to Presets
    Nothing happens in a vacuum, and I'd like to thank Daz for the youtube video, (which made perfect sense after I figured out how the utility worked,) and Sickleyield for her excellent tutorial on transfering M4Gens to M5Gens. It made my eyes glaze over with information specific to the gens, but also pointed me in the right direction for puzzling out how to make the Map Transfer work.
    *This tutorial does not cover the anatomical elements, as I do not have Victoria 8. Once you've completed the tutorial, if those materials are important to your art, you should have enough experience to work it out.
    Reserved for Recommendations and Links
    edited July 2017
    Converting Maps from one UV to another using the built-in Map Transfer utility.
    While we want to transfer the Victoria 7 materials for use on the Genesis 8 Female, we need to use the Genesis 3 Female as her stand-in for a number of reasons. In Part One, the Map Transfer Utility requires the object have both the source (Victoria 7) and target (Base Female) UVs. We'll also be working with Iray presets. Iray materials often include maps not used with 3Delight. This way, we'll convert all the maps for each template now.
    The very first thing you need to do is decide where your images will go for your presets. Once you've created presets for a character, you really won't want to move those images. I've created a folder structure in "My Library" textures folder similar to that of the default My DAZ 3D Library: C:\Users\ladair\Documents\DAZ 3D\Studio\My Library\Runtime\textures\L'Adair\Characters\Base Female\G3F\Victoria 7. The parent "G3F" directory will eventually hold converted textures for all of my "7" female figures.
    The second thing you need to decide is if you want to have an interim folder for your converted images and if so, where that temporary folder will be. I highly recommend the interim folder, and you'll see why in Part Two. You can always delete these copies later.
    Your destination folder in Step 2, below, is your interim folder if you're using one. Otherwise, it's your texture folder.
    Step-By-Step: The Map Transfer Utility
    1. In Render Settings, change the Render engine to 3Delight. (This may change in the future, but testing this in Iray in three versions of Daz Studio on both Windows 7 Pro and Windows 10 Pro computers showed me 3Delight still produces the most consistent results.)
    2. Open a window to the destination folder for your converted textures. Create a new folder if necessary. For example, C:\Users\ladair\Documents\DAZ 3D\Studio\My Library\People\Genesis 8 Female\MapTransfer\Temp. Highlight the path text, then copy and paste in step 9 below.
    3. Load Genesis 3 Female in Daz Studio.
    4. Apply the Victoria 7 All Mat preset for Iray.
    5. Open the Surfaces Tab. (It doesn't matter if you're in Presets or Editor.)
    6. Click on the Menu icon and select Map Transfer from the popup menu.
      Surfaces Menu with Map Transfer Highlighted
    7. In the Map Transfer dialog window, select all items in the Surfaces column and verify/set the Target UV Map to Base Female.
    8. Right-Click in the Templates column and select New Template. Repeat 3 times for a total of 4 Templates.
    9. Select all 4 Templates and set Template Options as follows:
      • Copy the path of the destination folder you opened in Step 2.
      • Back in the Map Transfer dialog, click on the small button with the "…" (ellipsis) for a label. This will open a window to select the folder.
      • Paste the path of your destination folder in the location bar. Hit the Enter key on your keyboard. The window should now display the destination folder. Once your folder name is displayed in the field at the bottom of the window, click on Select Folder.
      • Choose your file type. Click anywhere on the drop-down widget to change the selection. Maps can be saved in one of four file types: JPG, PNG, TIF or BMP. (I highly recommend PNG.)
      • Set your Baking Quality to 10 by moving the slider all the way to the right.
      • Skip down to Convert By Matching Properties and deselect the option. (It's on by default.)
        Map Transfer Dialog, Templates Selected.
        Note: I did not see this option in Daz Studio 4.8 on a Windows 7 Pro computer.
    10. Go back to the Surface column and drag and drop the Surfaces to the Templates as follows, (beginning with the last template and working your way up. It's faster):
      • Torso to Template 4
      • Legs and Toenails to Template 3
      • Arms and Fingernails to Template 2
      • Ears, EyeSocket, Face and Lips to Template 1
        Map Transfer Dialog with Templates Populated
      Note: It isn't necessary to convert the Eyelashes, Mouth/Teeth, or Eye maps. I've checked the maps and UV templates, and the Victoria 7 UVs are virtually identical to the base female UVs for these maps. (This is probably true for any base "7" female UVs.)
    11. Take a deep breath and relax.
    12. Click on Accept.
      Note: The transfer process can take a long time on older/slower computers. The images are optimized, converted and then rendered to file using the 3Delight render engine. If this process is taking a long time on your computer, skip forward to the next chapter for "Intermission" and come back here when the Map Transfer has finished processing.
    13. When the transfer is complete, go to your destination folder.
    14. Check to see that all the expected maps are there. At this point, you may need to rename your images. Depending on your options and/or operating system, (and apparently the phase of the moon,) your maps may use the Template as part of the image name. The Victoria 7 default loads with the no makeup face maps. This is also the Face 01 preset. There are five additional makeup options. At some point, if not now, you will want/need to tranfer additional maps for these options. Let's do one now.
    15. Apply the Victoria 7 Face 02 Mat preset to your Genesis 3 Female.
      Note: Victoria 7 loads with Normal Maps. So do the makeup presets. As Map Transfer has already created the face Normal Map in Step 12, you can save a bit of time by also applying the Victoria 7 Normal Maps Off preset after you load each makeup option.
    16. The Surfaces tab should still be selected. Click on the Menu icon and select Map Transfer from the popup menu.
    17. In the Map Transfer dialog window, select Templates 2 through 4. (Template 1 should contain Ears, EyeSocket, Face and Lips.)
    18. Right-click and select Delete Template(s).
    19. Select Template 1 and verify your settings have not changed, especially the path to your destination folder.
    20. Select the surfaces within Template 1 and verify the Target UV Map is still Base Female.
    21. Assuming nothing has changed in the dialog window, (and it really shouldn't have unless Daz Studio crashed on you,) click on Accept.
    Note: I recommend doing all the makeup options at this time. You have the utility set up with all the right options. Just apply the makeup preset to G3F, (apply the Normals Off preset as well,) open the Map Transfer dialog and hit Accept. Compared to setting it all up again later, it's fast and easy.
    And now... Time for Intermission.
    edited July 2017
    Intermission
    What? Intermission in a tutorial? Sure. Why not?
    We are all prone to make more mistakes when we're tired, and Part Two is definitely going to need your full focus.
    Besides, I want to tell you about a small graphics utility that is going to make some of this much easier on you. And it's free. I first discovered this little gem in the late 90s, and I haven't had a computer yet that it wasn't one of the first programs to get installed. What is it?
    Irfanview. Irfanview started out as an image converter. Even when I first started using it, the program did much more than that. But it's still small, and it's fast, and it has a great screencapture feature, and for our purposes today, a batch conversion/rename feature.
    The batch feature will let you rename the images from your Map Transfer, convert them to jpg with more control over the compression than you'll get from the Map Transfer—or from Photoshop—and move them to their final folder. All in a single operation. Of course, it can do even more than that, but you get to explore the other features on your own. Later. After you finish the tutorial.
    wink
    So what other secrets should I divulge now?
    ► PNG is my preferred image format. I use it for renders, I use it for screencaptures, I use it so much, I often forget to convert to jpg to upload images to my Gallery pages! Why? Because JPEG uses "lossy-compression," which in the simplest of terms means compression is attained by throwing away some of the pixel data. The higher the compression, the more data that's lost. But PNG is a "lossless" compression format, so I get the best of both worlds... data intact, and some decent compression.
    Most of the image maps you will be converting are in the JPEG format... already compressed, already with lost data to some extent. But some of the Normal Maps are TIF to begin with. So I recommend converting your images to PNG, rather than JPG, to get the cleanest images you can. You can even convert those normal maps back to TIF, with Irfanview. (And that's why I recommended PNG when going through the steps of Part One.)
    As an added bonus, using the beta 4.9.4.117 in Windows 10 and the beta 4.9.3.166 in Windows 7 both, my PNG images have transparent backgrounds. That makes it real easy to add a matching color backgound, especially to the Normal Maps.
    ► You may have noticed the path to my destination folder ended with "Map Transfers/Temp". I use the same folder for all my conversions. When I've finished one figure, I create a folder with her name within the Temp folder, i.e. "Victoria 7", and move all the images into that folder. I then drop the new folder into another subfolder of "Map Transfers", in this case "G3F". To make finding the folder easy, I have a shortcut to it in my top-level Daz folder on that drive. (Along with a few other shortcuts.)
    But I don't create my presets from these folders. These are my backup images. I may delete them after I have everything done, but if I mess up something, the renaming/conversion thing, for example, I can just delete my mistakes and start over.
    And now that your eyes have glazed over, it's time to get up and walk around; grab a beverage, pet the cat, chase the dog, (how did he get out of the backyard?)
    Meet me back here for Part Two in about ten minutes.
    wink
    edited July 2017
    Preparation, Organization, Application and Other Tedious Stuff
    Welcome back.
    After completing Part One, you should have, at least, all the images of Victoria 7's default maps for the Face_1001, Torso_1002, Legs_1003 and Arms_1004. Hopefully, you went on to convert the rest of the Face maps for the five makeup presets as well.
    What you still need for your presets are all of the maps for the Mouth_1005, Eyelashes_1006, Eyes_1007 and EyeMoisture_1008. (Though not all characters include the EyeMoisture map, Victoria 7 does.) When applying images to your figure, you could reference the images in Victoria's texture folder. However, I prefer to keep all the textures together in a single folder, as if my converted character were a product, so that's how these instructions are set up. (I sometimes need/like to make changes to the maps for a specific render, and it's just easier for me to have all the images for a figure in one place.)
    I also like to rename all of my maps, to distinguish the converted maps from the originals. Although our new maps will fit G3F, she can wear the original "7" materials without issue. So I'm adding G8 to the filename to tell me these are the images I converted to use with my G8 compatible material presets. For example, the original Victoria 7 images have filenames that begin with V7. I'll change those to start with V7_G8_.
    Using Irfanview To Prepare Your Maps.
    This section of the tutorial assumes you followed my suggestion and saved your converted maps to PNG format, that your system made the backgrounds transparent and that you downloaded and installed Irfanview during the break.
    1. Open a window to your Victoria 7 textures folder. Highlight the path text, then copy and paste in step 7 below.
    2. When you convert your transparent PNG images to JPG with Irfanview, it will fill in the background with the same background color you see when you open the utility. If the background isn't already white, change it in under Options->Properties/Settings->Viewing. Look for Main window color: with a long color field of the current background color. Clicking on either the color or the "change" button will bring up the familiar Windows color picker dialog. Click on the white square and click OK. Click on OK again to save the change and close the Properties/Settings window.
      Irfanview Properties/Settings Dialog Window with "Viewing" Selected
    3. Open the Batch Conversion window. You can access it via the File menu, but the keyboard access is simply a "b". The right column is where you locate and select the files you want to process. The left column controls what processes Irfanview will perform on the files.
    4. In the right column, browse to your interim folder. Select everything but the normal maps. Click on the Add button. A list of your selected images will be displayed below the buttons.
    5. In the left column, select Batch conversion - Rename result files. Select JPG - JPG/JPEG Format from the Output format drop-down. Click on the Options button to the immediate right. Using the slider or the arrows, set JPEG quality to 95 and click on OK at the bottom of the dialog.
    6. Also in the left column, click on the Options button for the Batch rename settings. Set the Name pattern to $N. In the Replace text (1) field, type V7 and type V7_G8_ in the field to the immediate right, (so the line reads "Replace text (1): V7 with V7_G8_".) Click on OK at the bottom of the dialog.
    7. In the Output directory for result files: field, paste the path to your Victoria 7 textures folder.
    8. Take a moment to insure everything is set correctly in this window. When you're ready, click on the Start Batch button. A popup window will display the progress. When it is finished, click on the Exit Batch button.
    9. Verify the images are now in your Victoria 7 textures folder, as JPGs and with the new name. It may be necessary to refresh the folder.
    10. Return to Irfanview and repeat the instructions for changing the background color, only this time, choose the light blue square for your normal maps.
    11. Open the Batch Conversion window. In the right column, select the normal maps and click on Add. In the left column, change the Output format to PNG, (for cleaner images.) Click on the Options button to the immediate right, set the Compression level to 9, and click on OK. The Name pattern should be the same, with $N in the text field. (To verify your changes are still in place, click on the Options button to the immediate right of the text field. Click on OK to save and close the dialog.)
    12. Verify the Output directory is the same.
    13. Click on Start Batch.
    14. Verify the normal maps are now in your Victoria 7 textures folder, as PNGs and with the new name.
    15. Now you need to copy the maps we didn't convert into your Victoria 7 textures folder. Open the Batch Conversion window again. In the right column, browse to Daz's texture folder for Victoria 7, C:\Users\ladair\Documents\My DAZ 3D Library\Runtime\Textures\DAZ\Characters\Genesis3\Victoria7
    16. Select all the maps for the mouth, (1005,) eyelashes, (1006,) eyes, 1007) and eyemoisture, (1008). Click on the Add button.
    17. In the left column, select Batch rename. The Name pattern should still be $N and clicking on Options should show your name changes are still there.
    18. Verify the output directory is still going to your Victoria 7 textures folder, and click on Start Batch. When the process is complete, your converted textures folder should have all the maps you need for all of the presets.
    19. Skip to Using Your New Maps On The Figure.
    Preparing Your Maps With Another Conversion Utility
    I like Irfanview and I've used it for a couple of decades. But if you've been using another program and are happy with it, you should use it. Basically, we are converting PNGs to JPGs, adding a white background color, and changing the name to include the G8 identifier. We are processing the normal maps separately, leaving them in the PNG format but adding a blue background, and adding the G8 identifier to the filename. (If you're not using Irfanview, I am assuming the above information is sufficient.)
    edited July 2017
    Part Two: From Maps to Model, (Cont'd.)
    In order to create Material Presets with the new images, we have to tell Daz Studio to use our image maps instead of the images provided by the vendor for the character; in this case, DAZ and Victoria 7.
    You'll want to copy and paste the location of your new maps frequently, so open a window to your Victoria 7 textures folder.
        1. In Daz Studio, load the base Genesis 3 Female and with G3F selected, apply the Victoria 7 All MAT option. It doesn't matter if you use Iray or 3Delight, the process is the same. (You may want to do both.) I'm going to use the Iray materials for this tutorial.
        2. With the G3F figure still selected, in the Surfaces->Editor, select "Surfaces" in the left column, (this will select all the surfaces.) Scroll down to UV Set in the parameters column, on the right, and change the UVs from Victoria 7 to Base Female.
        3. Save the file as a scene, somewhere easy to find. If Daz Studio crashes, you won't have to start over.
    Now comes the tedious part. In the Surfaces->Editor, you need to replace all of the images in all of the Surfaces.
        4. For every image in every Surface, you need to:
    • Click on the image icon
    • Browse to the new materials' location in the resulting window
    • Find the replacement image and
    • Double-click on the image to select and close the window.
    As you may recall from setting up templates in the Map Transfer utility, some of the maps are used for more than one surface. That means, in most cases, you can load the image for each parameter in all the related surfaces at once.
    Surfaces that do not share maps are: Eyelashes, EyeMoisture, and Torso.
    Maps that work for multiple surfaces are:
    • Face: Ears, EyeSocket, Face, and Lips.
    • Arms: Arms and Fingernails.
    • Legs: Legs and Toenails.
    • Eyes: Cornea, Irises, Pupils and Sclera.
    • Mouth: Mouth and Teeth.
        5. Select the EyeMoisture surface in the left column. Scroll down the parameters in the right column, looking for images. (As we are currently working with the Iray materials, there shouldn't be any images.)
        6. Select EyeLashes. Scroll down to the Cutout Opacity parameter. Click on the image icon, scroll to the top and click on Browse. Paste the path of the window you opened in step one in the location bar of this window and hit Enter. Find the V7_G8_EyelashesMapT01_1006.jpg image and double-click to select. If you want to verify the image has changed, hover over the image icon and the popup will include the full path and filename of the image.
        7. Select Torso. Beginning with Base Color in the right column, change the images for every parameter that has one: Click on the image icon, click on Browse, paste the path into the location and hit enter, double-click on the corresponding image from your converted maps.
    Okay, by now you are an expert on changing images! Only "a few more" to go.
        8. Select Mouth and Teeth, (click on one, ctrl+click on the other.) These two surfaces use the same image in both Base Color and Translucency Color. Change the image in Base Color, then you can click on the image for Translucency Color and select V7_G8_MouthMapD_1005 from the list of used images. Now scroll down to Base Bump and replace that image.
        9. Select Cornea, Irises, Pupils and Sclera. Like the mouth surfaces, these four use the same image, V7_G8_EyeMapD01_1007, in both the Base Color and Translucency Color parameters. Scroll down to Base Bump and replace that image as well. Click on Cornea. Scroll up to Refraction Weight and replace the image.
        10. Select Arms and Fingernails. Repeat the same procedure you used for the Torso, scrolling down and replacing images as you go, until you come to Top Coat Weight and Top Coat Color. These two surfaces use the same map here, but not the same parameter. Click on Arms. Change the Top Coat Weight image. As you used the same image for Glossy Layered Weight, find V7_G8_ArmsMapS_1004 in the list of used images. Now do the same for Fingernails in the Top Coat Color parameter.
        11. Select Legs and Toenails. Repeat the procedure you used for Arms and Fingernails. When you get to the Top Coat parameters, select first Legs and then Toenails and plug the specular map already in the list, V7_G8_LegsMapS_1003, into the the Top Coat Weight and Top Coat Color parameters, respectively.
        12. Select Ears, EyeSocket, Face, and Lips. Scroll down and replace images in each of the parameters. As with the other skin surfaces, Top Coat Weight will use the specular image also used in Glossy Layered Weight.
        13. Save your scene.
    And... you're done! Loading images, that is. For now.
    Could you use a break? I know I could. Let's take a short Intermission and meet back here in ten. (Or whenever you're ready to start saving your presets. I'll be waiting here patiently. Virtually, of course.)
    edited July 2017
    Intermission
    In Part Three, we're going to save our material presets. However, there is an issue with G3F eye materials on G8F eyes I'd like to address first. The UVs are the same, but the geometry (mesh) is not.
    On G3F, the EyeMoisture consists of two separate meshes, which were the "tear" and "EyeReflection" surfaces in Genesis 2. The second EyeMoisture mesh covers the Cornea and the rest of the eye. The Cornea and the Sclera are one mesh, with the Pupil and Iris both being separate meshes.
    Much has changed on the G8F eye. For one, the EyeMoisture "tear" mesh is now part of the Eyelashes anatomy addon. The rest of the eye now consists of two meshes, one on top the other and fully enclosed. On the top, or outside, is the new EyeMoisture/Cornea mesh, and underneath, or inside, is the new Sclera/Irises/Pupils mesh. But more than that, the ridge in the mesh around the iris is different. On the G3F eye, the ridge had the outer edges of the eye color. On the G8F eye, the ridge is completely outside of the eye color.
    With the Eye meshes so different, even using the same UVs and Surfaces, there are bound to be times when the G3F eye materials don't work right with the G8F eye. This is the case with the eyes for Victoria 7. Based on the numerous comments in The Commons about the "white ring" around the iris when G3F materials are used on Genesis 8, I suspect the problematic material presets for Victoria 7 are common throughout Genesis 3.
    I believe I've figured out the source of the "white ring." The Sclera settings for Victoria 7 are too "shiny" for the new mesh: too much Glossy, too much Reflectivity and too much Top Coat Reflectivity. Victoria 7 sets both Glossy Layered Weight and Glossy Reflectivity at 1.0 and Glossy Roughness at a mere 0.010! It also uses Top Coat to add even more Reflectivity, at the maximum settings.
    On the other hand, the Base G8F doesn't even use Top Coat, sets both Glossy Layered Weight and Glossy Reflectivity at .25, and Glossy Roughness at .40.
    How you want to proceed where the Scleras are concerned will be the first order of business when you return from intermission. Don't worry. It's no more difficult than anything you've already done following along with me here.
    Throughout this tutorial, we've been using the G3F figure instead of G8F. That's not going to change. As you already know, Daz has turned the G8F eyelashes into an anatomy addon. An assumption I've seen in the forums is you need a separate preset for the addon. But it isn't necessary.
    ► I've found applying the full/all mat preset to the addon will apply the correct settings and materials. That means you can select both the G8F figure and the G8F eyelashes and apply your G3F preset. In order to keep the Eyelashes with the full/all preset, we need to create those presets with the G3F figure. (The G8F preset that comes with the Starter Essential will apply settings to the eyelashes with only the figure selected, but I don't know how to do that, or if we even have the tools to do it that way, not being PAs.)
    ► And here's a tip for saving your new presets: Save your presets with the same names as the originals. This will allow you to copy the icon/tip images into your preset folder, delete the [filename].duf.png images and have great looking icons for your presets with minimal work.
    That's it for intermission. Don't forget to get up and walk around a bit, take a few deep breaths and oxygenate your blood, look at something besides a monitor to give your eyes a rest. The usual stuff.
    edited July 2017
    Saving Presets And, Yes, More Tedious Stuff
    Welcome back, again. This is the last chapter of the tutorial. (Go ahead. Breathe a sigh of relief. I did.)
    By the end of Part Two, you had G3F loaded in Daz Studio with Victoria 7's All Mat preset settings and your converted image maps, with Base Female for the UV Set. Have you decided where to save your presets? If not, do that now. (You can move these later, if you change how you want to organize things.) I put mine under Presets->People->Female->Genesis 8->Victoria 7 in My Library. (C:\Users\ladair\Documents\DAZ 3D\Studio\My Library\Presets\People\Female\Genesis 8\Victoria 7)
    Normally this is the point where you create your first preset. However...
    As I mentioned in the last Intermission, there are some decisions to be made about the material settings for the Sclera. Do you go with the settings from the Victoria 7 presets? Or do you make changes to compensate for the change in the Eye mesh? If you'd rather stay with the V7 settings, skip to Saving Your Main Preset, below. If you want to modify the settings, keep reading.
    Modifying The Eye Settings
    What I propose is you create modified materials as your presets, with two additional presets. The first additional preset will change the Cornea to the same settings as the default Genesis 8 base uses. The second additional preset will change the Sclera settings to give you back the high reflectivity in the original Sclera settings.
    1. The first thing you need to do is create the alternate Sclera preset, as everything is already set up. Material presets are easy to create. Select your G3F, of course, then go the top menu and click on File->Save As->Material(s) Preset…
    2. Browse to the location where you've decided to save your presets. Enter a filename for your preset. I used "Victoria 7 Eyes Legacy Sclera." Click on Save.
    3. In the Material(s) Preset Save Options dialog, click on the Menu icon in the upper right hand corner. In the resulting menu, select Uncheck->Uncheck All. (You're going to be doing that a lot, by the way.)
      Screenshot of dialog with flyout menus open, Uncheck selected.
    4. Now expand Sclera->Base->Glossy->Reflection to find Glossy Layered Weight, Glossy Reflectivity, and Glossy Roughness. Expand each in turn and select Value, by clicking in the box. Scroll down to and expand Top Coat->General-Top Coat Color and select Image. Click on Accept.
      Material Preset Options for Legacy Sclera Preset
    5. Now open the Surfaces->Editor and select, you guessed it, Sclera. Expand Sclera and you'll see the same breakdown as the save options. Select Sclera->Base->Glossy->Reflection and the left column will show only the Reflection parameters. Set Glossy Layered Weight and Glossy Reflectivity both to .25 and Glossy Roughness to .40. Now select Sclera->Top Coat->Top Coat Color, click on the image icon and select the current eye image from the list. (For me, that would be V7_G8_EyeMapD01_1007.jpg)
    6. Now create your Victoria 7 Eyes 01 MAT preset. With G3F selected, click on File->Save As->Material(s) Preset… Daz Studio will remember where you saved your last preset, so you should already be at your folder. Name your preset: Victoria 7 Eyes 01 MAT. Click on Save.
    7. In the Material(s) Preset Save Options dialog, click on the Menu icon in the upper right hand corner. In the resulting menu, select Uncheck->Uncheck All. Select Cornea, Iris, Pupils and Sclera by clicking in the box. With the four surfaces selected, click on Accept.
    8. Open the Surfaces->Editor again and select Cornea.
      • Remove the image map from Base Color.
      • Set Translucency Weight to 0
      • Set Share Glossy Inputs to Off
      • Set Glossy Color to light gray, (228, 228, 228)
      • Set Glossy Reflectivity to 0.296703
      • Set Glossy Roughness to 0.263736
      • Set Refraction Color to white (255, 255, 255)
    9. Create your custom Cornea preset: click on File->Save As->Material(s) Preset… Name your preset. I used "Victoria 7 Eyes Cornea Clear."
    10. In the Material(s) Preset Save Options dialog, click on the Menu icon in the upper right hand corner. In the resulting menu, select Uncheck->Uncheck All.  Select Cornea by clicking in the box. Click on Accept.
    To restore the your modified default eye settings, apply your new Victoria 7 Eyes 01 MAT preset. Now you're ready for...
    1. The main preset applies materials and settings to every surface of the compatible figure. This makes it the easiest preset to save: Select your G3F, of course, then go the top menu and click on File->Save As->Material(s) Preset…
    2. Browse to the location where you've decided to save your presets. If you created the alternate Eye presets, you should already be at your folder. Enter a filename for your preset: Victoria 7 All MAT. Click on Save.
    3. In the popup dialog, Material(s) Preset Save Options, notice all the surfaces have a check mark in the box, all the same color, indicating they are all selected. Click on Accept.
    Saving Other Default Presets
    Now we are going to create presets that use the default settings, but are only applied to part of the figure: Victoria 7 Eyes 01 MAT, Victoria 7 Face 01 MAT, Victoria 7 Eyelashes 00 MAT, (we're adding this one,) Victoria 7 Translucency Medium, Victoria 7 Teeth SSS OFF, and Victoria 7 Normal Maps On.
    Creating any Material Preset starts the same way:
    • Select your figure,
    • Click on File->Save As->Material(s) Preset…,
    • Browse to your preset folder,
    • Name your preset and hit Enter to...
    • Open the dialog window for Material(s) Preset Save Options.
    For the rest of the presets in this tutorial, you will always click on the Menu icon in the upper right hand corner and select Uncheck->Uncheck All.
    For brevity, I will say, "Prepare your [filename] preset, Uncheck All, and..." followed by the specific settings for that preset. Believe me, after a couple of these, you'll have it down like a pro.
    Ready?
    The first preset is the default Eye 01. Skip to the second preset, if you've already saved Victoria 7 Eyes 01 MAT in Modifying The Eye Settings, above.
    1. Prepare your Victoria 7 Eyes 01 MAT preset, Uncheck All, and then select Cornea, Iris, Pupils and Sclera by clicking in the box. You should see a check mark in each surface selected. Now click on Accept.
    2. Prepare your Victoria 7 Face 01 MAT preset, Uncheck All, and then select Ears, EyeSocket, Face and Lips. Click on Accept.
    3. Prepare your Victoria 7 Teeth SSS OFF preset, Uncheck All, and then select Teeth. Click on Accept.
    4. Prepare your Victoria 7 Eyelashes 00 MAT preset, Uncheck All, and then select EyeLashes and EyeMoisture, (to use on the G8F Eyelashes anatomy addon.) Click on Accept.
      The next presets are a bit more work.
    5. Prepare your Victoria 7 Translucency Medium preset and Uncheck All. Select the Translucency Weight->Value for each Skin surface—Torso, Lips, Legs, Face, Ears and Arms:
      • Expand the surface, (click on the arrow, or double-click.)
      • Expand Base
      • Expand Diffuse
      • Expand Translucency
      • Expand Translucency Weight
      • Select Value, by clicking in the box
      Note: I recommend starting at the bottom of the properties and working your way up. Once expanded, the tree will go below the bottom edge of the dialog window. This way, you won't have to keep scrolling, which saves time.
    6. Do not collapse the tree between surfaces. Before accepting your selections, double-check each surface has the Translucency Weight->Value checked, and that no other properties are selected. Click on Accept.
    7. Prepare your Victoria 7 Normal Maps On preset and Uncheck All. Select the Normal Map->Image for each Skin and Nail surface—Torso, Toenails, Lips, Legs, Fingernails, Face, EyeSocket, Ears and Arms:
      • Expand Base
      • Expand Bump
      • Expand Normal Map
      • Select Image
    8. Do not collapse the tree between surfaces. Verify you selections are correct. Click on Accept.
     That takes care of all the presets based on the default character materials and settings. Now let's tackle the variations.
    edited July 2017
    Saving Character Option Presets
    Victoria 7 Iray presets include six makeup options, four eye color options, three eyelash options, two Translucency level options, as well as Normal Map On/Off, and Teeth SSS On/Off presets.
    One of each is default, except for the eyelashes, but we created a default anyway.
    Each of these presets will have identical settings in the Material(s) Preset Save Options dialog as their default counterparts. The changes are in the actual materials and/or settings on the figure.
    At this point, we are combining what you learned in Part Two with what you've already learned in Part Three. One by one, you'll apply the Victoria 7 preset, replace the original images with your converted images, and then create the option preset.
    First, to make it a lot easier on you, locate the Victoria 7 folder under the Surfaces->Presets. For Iray, that's Default->Iray->Feminine->Victoria 7. There are two columns, the folder structure on the left and the preset icons on the right. In the middle, there is a very small triangle pointing toward the left. Click on that to expand the right column. With only the icons showing, this column won't change when you go back to the Surfaces->Editor.
    From two columns to one, locking the presets view.
    Second, open the folder with your converted images and copy the location. You'll need the path in several of the steps that follow.
    Special Presets
    Let's start with the easiest, the Victoria 7 Normal Maps Off preset, as it only removes the Normal Map from the Skin and Nail surfaces.
    1. Apply the Victoria 7 Normal Maps Off preset. Verify the normal maps have been removed, in the Surfaces->Editor, if you'd like.
    2. Prepare your Victoria 7 Normal Maps Off preset and Uncheck All. Select the Normal Map->Image for each Skin and Nail surface—Torso, Toenails, Lips, Legs, Fingernails, Face, EyeSocket, Ears and Arms:
      • Expand Base
      • Expand Bump
      • Expand Normal Map
      • Select Image
      • Verify settings and Accept.
    3. Here's another easy one: Apply the Victoria 7 Translucency High preset.
    4. Prepare your Victoria 7 Translucency High preset and Uncheck All. Select the Translucency Weight->Value for each Skin surface—Torso, Lips, Legs, Face, Ears and Arms:
      • Expand Base
      • Expand Diffuse
      • Select Value
    5. Now apply the Victoria 7 SSS Teeth On preset. This preset uses only two images, the texture and bump map, and will still be in the list of images in use.
    6. In the editor, select Teeth. First one and than the other, click on the image icons for Base Color and Translucency Color, locate and select your V7_G8_MouthMapD_1005.jpg for both of these setting. Now scroll down to the Base Bump, click on the image icon, and then locate and select your V7_G8_MouthMapB_1005.jpg image.
    7. Prepare your Victoria 7 SSS Teeth On, Uncheck All, select Teeth, and Accept.
    Eyelashes
    1. Now let's move on to the Eyelashes, which only have one image to change. First, in Surfaces->Editor, select Eyelashes->Geometry->Cutout Opacity. Go to the Surfaces->Presets tab and apply Victoria 7 Eyelashes 01 MAT.
    2. In the Editor, select Cutout Opacity. Click on the image icon, select Browse, paste the path to your folder of converted images into the location bar and hit Enter. Double-click on your eyelashes image that corresponds with the original you are replacing.
    3. Prepare your Victoria 7 Eyelashes 01 MAT, Uncheck All, select Eyelashes, and Accept.
    Repeat the above steps using first Victoria 7 Eyelashes 02 MAT and then Victoria 7 Eyelashes 03 MAT.
    Eyes
    1. The eyes use only two images, a texture and a bump map. But instead of applying the Victoria 7 Eye presets, we're going to work with these as is. It won't matter if you chose to modify the default settings or not. All you need to do is replace the texture map wherever it's used.
    2. In the editor, select Cornea, Irises, Pupils and Sclera. Click on the image icon for Base Color and select Browse. You will now be in the folder with your converted images. (The last time around, highlight and copy the location for use with the Face/Makeup instructions, below.) Double-click on your V7_G8_EyeMapD02_1007.jpg image. Now click on the image icon for Translucency Color. Select V7_G8_EyeMapD02_1007.jpg from the list of images in use.
    3. If you modified the default eyes, click on Sclera, then on the image icon and select V7_G8_EyeMapD02_1007.jpg from the list of images in use. Skip this step if you did not modify the default eyes.
    4. Prepare your Victoria 7 Eyes 02 MAT, Uncheck All, select Cornea, Irises, Pupils and Sclera. Click on Accept.
    Repeat the above three steps for Victoria 7 Eyes 03 MAT and Victoria 7 Eyes 04 MAT.
    Face/Makeup
    1. Apply Victoria 7 Face 02 MAT.
    2. In the editor, select Ears, EyeSocket, Face, and Lips. Start at the bottom and work your way up. The images for all but Base Color and Translucency Color are already in your list of images in use. Restore V7_G8_FaceS_1001.jpg to Top Coat Weight; Restore V7_G8_Face_NM_1001.png to Normal Map; Restore V7_G8_FaceB_1001.jpg to Base Bump; Restore V7_G8_FaceS_1001.jpg to Glossy Layered Weight.
    3. Hover over the image icon for Translucency Color and make a mental note of the image name. They aren't necessarily the same as the preset number. Then click on the icon, select Browse, paste the path to your folder of converted images into the location bar and hit Enter. Double-click on the SSS image that corresponds to the image it is replacing.
    4. Click on the image icon for Base Color, select Browse, paste the path to your folder of converted images into the location bar and hit Enter. Double-click on the FaceD image that corresponds to the preset number. (i.e. V7_G8_Face02D_1001.jpg)
    5. Prepare your Victoria 7 Face 02 MAT, Uncheck All, select Ears, EyeSocket, Face, and Lips. Click on Accept.
    Repeat the above five steps for Victoria 7 Face 03 MAT, Victoria 7 Face 04 MAT, Victoria 7 Face 04 MAT, Victoria 7 Face 05 MAT and Victoria 7 Face 06 MAT presets.
    And now, believe it or not, you have finished the tutorial! (Feel free to celebrate. You've put in a lot of work to get here.)
    edited September 2017
    Now that you have completed the tutorial, I think you will agree with me that the Transfer Map utility is quite simple and easy to use. And creating Material Presets is pretty easy, too. The bulk of the work comes when you have to apply the new images to the material settings on your figure. Also easy, but repetitive, boring, and tedious!
    But the thing about repetition, boring or not, is you retain what you've learned. I suspect you can now convert another "7" figure to use with G8F with little or no need to refer back to the tutorial.
    Bookmark this thread anyway. If you don't use the Map Transfer utility for several months, you may want to skim the tutorial to refresh your memory. And when you meet someone in the community who could benefit from the information here, I hope you will share the link.
    Thank you for hanging out with me, putting up with my oddball sense of humor, and sticking it out for the entire tutorial!
    And here's a closeup of G8F wearing my new Victoria materials. She's also sporting V7's shape.
    "Sophisticated Lady"
    Close up from Sophisticated Lady, by L'Adair
    edited July 2017
    F.A.Q.
    Q. Can I follow the steps in this tutorial to convert other generations to the G3F UVs for use with either Genesis 3 Female or Genesis 8 Female?
    A. No. The differences between the unique UVs of the DAZ "7" figures and the G3 Base Female are relatively small. It's like taking a trapezoid, pulling the short ends out and pushing the long ends in to convert it to a rectangle. Or vice-versa. (Fig. A) But the UVs of generations before Genesis 3 are so dissimilar to G3, it's like trying to convert a square to a free-form shape. (Fig B)
    Shapes
    Reserved Just Because... because if I don't, I'll find I need it! lol
  • jakibluejakiblue Posts: 7,281
    Reserving this post to post my screams of horror, hair tearing and tears cos I am a dumpkopf when it comes to things like this.
    laugh
  • IceDragonArtIceDragonArt Posts: 12,548
    Oh my gosh thank you, thank you thank you! lol.  I'm assuming this will work for moving G2 up to G3 as well?
  • DiomedeDiomede Posts: 15,221
    Unreserved praise to you, L'Adair.  Thank you very much.
  • BlueIreneBlueIrene Posts: 1,318
    Wow. What an awful lot of work you must have put into this! I look forward to having a go at it when I can carve out a bit of time. Meanwhile, I can't wait to see everyone else's results. You're a very thorough teacher, L'Adair. Thank you :)
    No, I'm afraid not. The UVs are too different. That was perhaps the biggest complaint DAZ got when they released G3, that the materials weren't compatible. Made quite the cottage industry for Cayman Studio's with his/their Legacy UVs products.
    You can convert the "6" figures materials to base materials, though, and then they'll work with the corresponding version of Cayman's Legacy UVs.
    And... you're welcome, you're welcome, you're welcome!
    edited July 2017
    @jakiblue, I hope you plan on including a video... with audio! laugh
    @Diomede, you're welcome. Unreservedly. wink
    @Astracadia, it was a labor of love: love of the art, love of the community... but I admit, I was getting eager to post long before I was finished! Thank you. And of course, you're welcome.
    smiley
    Eh, no big deal, I am sure I will scoop up the G2 to G3 at some point although I am perfectly happy with G2f as she is.  although, if I could get her to G8 with those expressions.... lol. Thanks!  I'm still super excited about this lol.
  • Worlds_EdgeWorlds_Edge Posts: 2,152
    Thank you so very much for all your hard work on this!  I've bookmarked and will try it when I've plucked up the courage.  Haven't done a thing with maps and such yet...
  • yakasyesyakasyes Posts: 0
    Thanks for the detailed walkthrough. Can you explain what you mean with the above? By explain I of course mean create another comprehensive guide with intermissions. Basically I bought this thinking it would work with V8, what can one do other than buy V4?
    Well, we mix characters and materials all the time. You can always create your G2F shape morphs for G8F, and then apply G3F materials. Otherwise, to use your G2F materials on G8F, you're going to need Cayman's Legacy UVs for Genesis 8: Genesis 2 Female. I think that's what you meant, above, but just to be on the safe side, (for anyone else reading this thread,) the Cayman product that makes G2F materials usable on G3F will not make materials that can then be applied to G8F.
    You are most welcome, @Worlds_Edge. But please, don't let the length of this tutorial intimidate you. The Map Transfer utility is really very simple to use. There is only the one dialog page. Creating material presets is also quite simple. I am detailed in the instructions to try to ensure no one gets overwhelmed and gives up. (In fact, I expect some folks will think the instructions are too elementary!)
    And when you do give it a go, feel free to come in here and post your questions. If something is unclear, I want to know, so I can revise it.
    smiley
    To use your V4 materials on G8/V8, I believe the best solution for you is to get Legacy UVs for Genesis 8: Victoria 4. Cayman's product provides "Victoria 4 legacy UV maps for Genesis 8 and the geografts" so you shouldn't need to have V4 in order to take advantage of the product.
    The only other suggestion I have is to return Amy and get your money back so you can purchase a G3F that will meet your needs. If you're heart is set on Amy, you need the Legacy UVs.
    You don't need another guide, you can use this one.
    A "6" figure is any DAZ base figure for generation 6, aka Genesis 2. So Victoria 6, Gia 6, The Girl 6, and so. Each of these "base figures" has it's own, unique, UVs. Let's say you have Victoria 6 and Cayman's Legacy UVs for Genesis 8: Genesis 2 Female. You would follow along with this tutorial, using Victoria 6 everywhere it mentions Victoria 7, and Genesis 2 Female everywhere it mentions Genesis 3 Female or G3F. (There are some things specific to V7, like the issue with the eyes. But Cayman has a solution for the eyes so you can skip that bit.) When you are finished, you should have a folder of presets of V6 for G2F UVs. Those are the materials you'd use with Cayman's product.
    I hope this answers your questions.
    I think you do need V4 figure tho - the skins need to be in .duf format for them to work with Cayman Studios stuff....if the V4 Elite Amy isn't in duf format, you need to load it onto V4, then save as a material preset in the duf format.
  • NovicaNovica Posts: 23,905
    SO much hard work to do a tutorial- thanks for sharing your expertise and for all the time this took to do it. Concise, to the point, and will help a LOT of people. Don't forget to add the link to your signature so more people will know about it. People sometimes forget we're here in the Art Studio!
    edited July 2017
    Thanks, Jakiblue. I forgot about the file type issue, not using V4 much. I believe it's still possible without V4, if you have Victoria 4 for Genesis 2 Female and one of Draagonstorms's scripts. I just applied Amy to G2F without opening V4. I have the aforementioned product and the V4 Skins Auto Converter for Genesis 2 Female(s). I bought it about a month before her batch converter was released. (I could have returned it and got the batch converter, but I had no clue about the 30 day policy!) This script requires G2F be loaded in the scene, and it applies the materials to the figure. You then need to save them as a .duf material preset. I'd say saving an entire figure's presets would be as tedious as doing the same through my tutorial! lol
    The V4 Skins Batch Converter to Genesis 2 Female(s) doesn't explicitly state it saves to .duf files, but I think it does, based on the statement: "... you can select one folder, and the script will convert all of the .DS, .DSA or .PZ2 files, that are Material Presets, in that folder and it's subfolders to Material Presets that will work seamlessly with Genesis 2. ... Then you just press the Process button and let the script do the rest."
    The thing is, if you don't already have these utilities, you're looking at $36-$38. And that doesn't include the cost of Cayman's product. Another reason, perhaps, for @yakasyes to opt for returning Amy...
    edited July 2017
    Thank you, @Novica. Once I get the all the images up, I'll be adding it to my signature. And to the Art Studio stickied List of links to useful tutorials. I'll also announce it in the Morphs for G3 to G8 thread. (While I know it can help anyone trying to figure out the Map Transfer tool, I wrote it with all those folks who are creating shape morphs for G8F in mind.)
    ETA: I've shared the link a couple of places, so I went ahead and announced it in the morphs thread. I think I'll still wait until I've added all the images before I put the link in my signature, though...
  • 3Diva3Diva Posts: 11,728
    Whoa, this is going to be hugely helpful! Thank you so much for the great tutorial and all your hard work, L'Adair! You are awesome! heart
    blush
    You're welcome.
  • dracorndracorn Posts: 2,345
    Wow, L'Adair.  This is professional-looking.  This comes from somebody who has written technical manuals.
    Great job!
