FREEBIES: 360 deg. Scenic ANIMATED Environment SKYBOXES !
Free 360 spherical skyboxes of scenic environments and atmospheres for creating your perfect static render set, or animated video or game scene. The country environments range from: Forest, River, Swamp, Pasture, Valley, Tropical Isle, and Mountain Tops. Animated skyboxes have cyclic motion of atmosphere, ocean/water, flora , fauna and weather effects so that the environment comes alive. The double sided textures of the skyboxes and skydomes are projected on a cube or dome (obj) for easy implementation in your environment. Animated skyboxes use a series of .png images that are[removed]promptTag("link"); swapped in timed sequence to create the effect with your game engine. See implementation samples at FarmPeeps.comFarmPeeps.com
